OwnerCS »
https://forums.nicoclub.com/ownercs-u161666.html
Sat Mar 21, 2015 5:32 pm
Good news. The whine was coming from the A/C pulley splash shields. I replaced the other two pulleys and didn't find anything that would cause noise. So I decided to slightly loosen the 14mm bolt that holds on the A/C idler pulley and the noise went away. After a couple of tries and modifications to the rear shield, I decided to just remove it. That took care of 70% of the noise.
For the front shield, I happened to have a slim washer to go between the bearing and the shield. The protective shields on the A/C idler pulley were ringing like a couple of bells. The problem was with a new out of the box OEM assembly that I received this week.
The Dayco idler pulleys are nice and quiet. I could feel some bearing shift in a couple of the pulleys so I'm glad I replaced everything. The PS pulley was the only pulley that didn't show any signs of wear.
