G37S Diff Comparo for M45 Pics
ken in az
Car: 2011 Infiniti M56
2002 Chevy Silverado
1989 Nissan 300ZX
2008 Ford F250 Diesel/Canam X3 Turbo
Both the M45 and the G37S use a common differential called the R200 which refers to the 200 millimeter Ring gear diameter (nearly 8 inches). The M45 2006 model utilizes a 3.357:1 ratio where the G37S uses a 3.692:1 ratio.
Switching from the Stock M45 differential to the G37S ratio is an obvious mechanical advantage to aid in acceleration mainly helping a cars ability to leave the line harder to help 60 ft times. After that there really isn't much a difference in acceleration except you spend a shorter amount of time in each gear.
Here are the pics of the differences involved in the swap.
M45 Axle shaft is the short one
M45 Axle shaft is longer
M45 on the right
M45
G37S
Mark the driveshaft orientation to the diff companion flange
M45 Driveshaft flange is 6 bolt
Remove companion flange - impact gun is a near necessity
M45 Flange on left
M45 flange bolts up just need to clean it up and lube the mating surface with gear lube
Switch is easy as 1, 2, 3
I'll be test driving the car tonight to see if everything works as planned, but that is it in a nutshell. Pretty darn easy!
DRIPS
Car: 2003 Infiniti M45
Nice! Let us know how it goes. ALso, what was the cost of the swap? Total time to do the swap?
ken in az
1989 Nissan 300ZX
DRIPS wrote:Nice! Let us know how it goes. ALso, what was the cost of the swap? Total time to do the swap?
Took me about 4hrs but could have done it faster.
Cost - don't expect to find a diff for this price - I was very lucky
G37S diff = $199Axles = $199
ken in az
1989 Nissan 300ZX
***A Small update***
The inner CV joints from the M45 to the G37S are not compatable. The G37S spline count is less and slightly smaller diameter. This in not a bad thing though.
I took them out of the car and realized how much room there is for movement and there ia pleanty of room left in the G37S inner CV joint to accomodate the M45 suspension travel.
When I first installed them the short side was too short and the long side axle was too long. Thjis was an easy fix because when i reinstalled the boot I realized they make the CV joint air tight. So when I installed the longer axle it compressed the joint creating positive pressure inside the joint like a balloon. I simply let out some air and they now fit like a charm.
So to conclude:
G37S Rear axles are 100% compatable when using the G37S rear differential.
I still have not been able to get my VDC OFF, SLIP, RAS lights to turn off. I'm going in to get the STeering angle sensor zero'd out on monday to see if that helps and if it doesn't I have ordered the Dakota Digital SGI-5c to recalibrate the transmission speed sensor.
jazzy m45
Car: 2006 Infiniti M45 Umbria Gray Adv. Tech
ken in az wrote:Pretty darn easy!
Says who, did Einstein just get ASE certified?
Let us know what results you get in performance gains!
seymore4
Car: 2012 M56
Professional UPREV tuner
Awesome DIY, did you ever get the lights to go off on the dash? Or just deal with them?
KoMikeey
Car: 2007 M45 S, Aero kit, Diamond Graphite, Uprev, Injen CAI, G37 sport vlsd differential swap, Full custom exhaust (removed secondary cats) into an x pipe through the megan exhaust.
so if i got my car uprev'd and get this g37 s rear diff would i have to go back and retune the shift points?
seymore4
Car: 2012 M56
Uprev cannot change the shift points, all it can do is bump the line pressure and influence how the torque converter locks up. None of that has anything to do with the rear dif however so you'll be fine
KoMikeey
uprev there are transmission shift points arent there. and upgrading the g37 s dif doesnt it change the shift points?
seymore4
Car: 2012 M56
KoMikeey wrote:uprev there are transmission shift points arent there. and upgrading the g37 s dif doesnt it change the shift points?
No and no.
EniGmA1987
Car: '06 Infiniti M35 Sport
Changing the rear differential will not alter where the computer has the shift points set at, but you will get to those points slightly faster
clintguy
Car: 2003 G35 Coupe - Chone Figgins Edition
2007 M45 Sport
I am interested in going this route with my 2007 M45.
Two questions:
1. For the rear G37S axles, does it matter if they're from a coupe or sedan?
2. Do you also need a G37S drive shaft?
Thanks!
clintguy
2007 M45 Sport
Can anyone please help with my questions above or point me to a helpful resource?
Thanks.
mexillis
Car: M45s
For #1 i believe it doesnt matter and no for #2.
Ilya
You have to be a little patient. I've been on this board for a while and this is the first time I've even seen this thread. It's clearly not a common thing done to these cars. Posting in the thread twice in one day isn't going to help.
built2makeit
Car: 2007 Infiniti M45
am i the only one who has no idea what's going on?
EniGmA1987
^^^^^ Pretty much ;)
Ken has not been active for a LONG time now, but I *think* he still gets an email update for replies to this thread. So he may actually show up and give some answers for you.
I dont remember if the issue of the VDC, RAS, and SLIP lights was ever solved on the M45 but I have this mod (and the exact piece Ken used to do this since he sold it to me) and I have no errors or issues at all on my M35. I have been running this G37s rear differential for about 3 years now. I believe I still have the G37 axle's if you want to buy them off me when you do this mod, they are not needed if you do this on a 35.
clintguy
2007 M45 Sport
Thanks, mexillis and EniGmA1987.
I did my best to stalk all of Ken's old posts, and I recall reading somewhere that he did fix the lights issue. But I also thought I saw some mention about the drive shaft too. Cool. At least I get to save a couple hundred bucks by not needing that!
I picked up the rear diff and axles last night. I am also going to get a Transgo installed... and, oh yeah, try the 4.083 gear in the M45. :woot:
mexillis
Car: M45s
Where and how much? What Nissan did you get the 4.08 gears from?
clintguy
2007 M45 Sport
I picked up the rear diff and axles for ~ $540 on eBay.
I grabbed the ring and pinion for $490 from Fontana Nissan.
sergofast
ken in az wrote:***A Small update***
So to conclude:
Sorry to raise this from the dead but I read in one of your other post that the G37s dif is a direct swap for the m35 guys. Couldnt you use stock m35 axles with this swap in lue of G37s axles?
