mexillis wrote:Ken, do the G37S diff. only work for the M45? Also have you added the dakota digital sgi-5c calibration box yet to fix the cruise control? One last question can u do a brake stand now? lol
I have not done the dakota digital box mod yet. I might not even mess with it to be honest - I rarely use cruise control.
I don't know about the compatability with the M35, I know it will work but I don't think you need the axle shafts....it should just bolt in and the M35 axles should work. "should" being the key word there because I have never stuck my head up an M35's butt to see.
Oh and brake stands - I just unplug the brake switch connector under the dash. If you have have a place to go where you dont need brake lights, just look up under the dash at the connectors on the brake pedal. there should be 2, one white and one brown, and unplug the white one with 4 wires. Before you do that though, make sure the car is running and the transmission is in neutral with the ebrake on. Otherwise you cant start the car or take it out of park - lol Then just brake stand burnout all day long
For me, I can mash the gas, light em up so much and shift to second gear and continue the burnout into second gear up to redline burning posi. good times
