transmechZ wrote:It's around 4 quarts for a drain/refill. Check the fluid level while running in park, at idle, and level, and lukewarm 100-104 degrees F. I would dedicate a pump for this fluid refill unless you have a lot of vehicles using the Nissan Matic S ATF fluid.
Right so I did it and I collected about 4 quarts just as you said. Anyways - the job is much simpler than one would think. There are actually two ways to do it. (make sure you have the right tools to loosen and tighten both drain plug and fill plug before you start - a fluid pump is necessary and instead of using a charging pipe I used a rubber hose which fit perfectly into the fill port with no room for fluid to leak out another words a tight fit so it didn't leak when i filled it.)
The first being the practical method in which you will simply drain the fluid at cold temperature and measure how much you collect. Then using a 19$ quart/gallon pump acquirable at your standard auto parts store (autozone or advance auto parts etc.) you just pump however much you measured when you drained it - into the tranny via the fill port which is the plug closest to the front of the vehicle (the one closest to the rear on the tranny case is the drain plug). Obviously you want the drain plug back in for when you do this part.
The other method is a more literal approach that goes off of the method in which Infiniti themselves does it. As some may have already read in the TM section which explains how they do it on page 269 all you really need to do is drain the fluid and pump new fluid back in the same way as the first method, however, this time you will need a module that measures tranny temp via the ecu plugin. Drain the fluid when it's cold then put the the drain plug back on and remove the fill port plug -> pump in about 4 qts, run the vehicle until it's at 40 degrees celsius or 104 degrees fahrenheit. Then while the car is running you just remove the pump's hose from the fill port and watch to see if fluid comes out (if fluid comes out in a stream then it's extra fluid and is overfilled as essentially the fill port is an overfill port.) If it comes out only a little and just dripping then you will need to pump in more new fluid. The result you want is for the transmission fluid to come out in a steady stream while the car is running (drain plug should remain in this whole time since after you put it back on when you originally drained the old fluid, fill plug is what you take on and off to measure fullness) and tighten the fill plug back on once the steady flow of tranny fluid coming out of the fill port stops and starts to just drip. Then start the engine and let it run for like 3 minutes or so and shift through all the gears to mix around the new fluid. Now make sure the temperature is 40 celsius or 104 fahrenheit again. Next remove the fill port plug again and wait until it starts to drip again and pump another quart in - then remove the hose that is connected to your pump from the fill port again and check to see if it comes out in a steady stream of fluid or just dripping. If it does not come out in a steady stream after removing this time then you will need to put in another quart (but this will probably not happen) most likely it will come out in a steady stream and at this point you will wait until it starts dripping again and put the plug back in while its just dripping. That's it.
Personally, I prefer the first method - and since it was just a drain and fill I will be driving for a few hundred miles or so while all the new tf mixes with the rest of the old fluid that doesn't drain out before I do it again. (total transmission capacity is 9.75qts) 1/2 drain and fills complete.
