G35X Undershroud
A forum for approved vendors of specialized, limited-production parts. Help small businesses that cater to Nissan enthusiasts and score some unique, useful parts! Contact [email protected] for approval and rates.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
This is the replacement for the horrible plastic aero splash shield for the G35X.
Brushed Aluminum version is:
$165 SHIPPED
Black Powdercoated version is:
$185 SHIPPED
As noted in the RWD version, this:
*Protects the engine better
*Increase high speed stability for the bumper
*Includes an oil access door for quick oil changes
*Is designed to keep clearance to a maximum (especially useful for lowered vehicles)
*Helps channel air through the engine bay to keep the vehicle running cool
Brushed Aluminum Version
Last edited by tollboothwilley on Thu Dec 06, 2012 8:01 pm, edited 4 times in total.
audtatious
Have you noticed any additional noise from the metal due to road debris? Just curious.
tollboothwilley
Nope. I haven't had any noise. Obviously this sits under the engine so you don't have tires kicking up stuff directly at it.
Its awesome. Everyone who has one loves the extra rigidity especially as it pertains to the bumper. I can only imagine how much better this is at higher speeds as well.
audtatious
People will love it for easier access to the oil filter as well
tollboothwilley
Absolutely. Even if you ever need to remove the rear section, you still don't have to remove the bumper section. Saves a ton of time, plus its just that much better than the stock POS.
AndyK99
Car: 2006 G35x
Hi,
I need one. Can you please contact me by PM and let me know how to go about buying this?
Andy
AndyK99
Car: 2006 G35x
AndyK99 wrote:Hi,
Andy
Hi TollBoothWilley,
Thank you for your PM. For some reason I cannot reply to the PM since looks like you have disabled your PMs. So I will ask my questions here if I may.
1. Does the shroud come powder coated. If not, please let me know how much extra would that cost.
2. I read here (http://g35driver.com/forums/g35-sedan-v ... led-3.html) that the coolant drain hole was on the wrong side. Is it still the case or will you correct it when you make the new ones.
Thanks,
Andy
tollboothwilley
You probably can't send PM since you are a new member with less than 10 posts. My PM's are not disabled.
The pictures show where the hole is located. It is on the drivers side - the side that the lower coolant hose and radiator drain from. However, if you drain your radiator you will probably take off the rear section of the shroud anyways.
From that other thread when they talk about the hole being on the wrong side...that wasn't meant for coolant to begin with. It was for AUTO trans fluid drainage. I have a hole on both sides now - 1 for coolant and 1 for AT fluid.
I dont powdercoat them. Its aluminum and does not rust so there is no reason for PC. If you want it a different color painting it is much more cost effective. You can get a can and spray it yourself for $5.
AndyK99
Car: 2006 G35x
Thanks a ton tollboothwilley. Can you please let me know when I can get one. I need one really bad and have been driving without one for a couple of weeks now.
tollboothwilley wrote:You probably can't send PM since you are a new member with less than 10 posts. My PM's are not disabled.
tollboothwilley
I'm gonna send you a PM with my phone number.
jerrykid323
Car: 2007 INFINITI G35 Sedan
may I ask what are the pluses to having this? I am a newb cus I just bought a G35
tollboothwilley
Benefits:
Metal protects better than plastic
oil door - you can remove 2 bolts and easily change your oil without taking off 16 bolts & 3 clips (for 2007 g sedan)
bumper rigidity - better airflow and stability at high speeds
Stock plastic tends to rip off from the bumpers from so much flex and this won't
J-Roc
Will this fit the coupes as well?
tollboothwilley
I have a version that fits the coupe. I have a version for all 2003-2011 G35/G35X/350Z/370Z/G37/G37X
I'll send you a PM.
tollboothwilley
New batch of AWD shrouds hot off the press....get them while in stock
audtatious
ker-bump for a great product!
tollboothwilley
thanks buddy
tollboothwilley
have a couple in stock
audtatious
These would make a great Xmas gift for a G owner!!
tollboothwilley
tell you wives, tell your girlfriends, tell your husbands...
:p
Return to “Fabricators' Market”
