G35 Specifications
rydwhite
Car: 2003 G35 Coupe
2003/2004 G35 Sedan
Engine: 3.5 liter V6 (VQ 35)
Drive Type: Rear-wheel drive/Optional All-wheel drive (G35X)
Horsepower: 260 @ 6,000 RPM
Torque: 260 lb-ft @4,800 RPM
Suspension:Front: Independent, forged-aluminum multi-link with coil springs over ripple-control shock absorbers, stabilizer bar.Rear: Independent, forged-aluminum multi-link with coil springs, outboard ripple-control shock absorbers, stabilizer bar.
Valvetrain : DOHC, 4 valves per cylinder with microfinished camshafts and Continuously Variable Valve Timing Control System (CVTCS) for intake valves.
Intake system: High-flow induction system
Compression ratio: 10.3:1
Brake Rotors: 11.7” x 0.9” front rotors/11.5” x 0.6” rear rotors
ABS Type: Computer-controlled 4-channel, 4-sensor with Electronic Brake force Distribution Assist
Turning Diameter: 36 feet
Wheels:Base, Leather Model: 6-spoke 7” x 17” aluminum-alloyLeather, 6mt Model: 5-spoke 7” x 17” aluminum-alloy
Tires:Base, Leather Model: 215/55R17 V-rated all-season performanceLeather, 6mt: 215/55R17 w-rated performance
Wheelbase: 112.2
Overall Length: 186.5
Overall Width: 69
Overall Height: 57.7
Track (front/rear): 59.1/59.3
Coefficient of drag: 0.27 Cd/0.26 Cd with Aero
Head Room (front/rear): 40.1/37.9
Leg Room (front/rear): 43.6/33.6
Shoulder Room (front/rear): 56.4/55.5
Hip Room (front/rear): 52.2/54.1
Interior Volume: 98 cubic feet without sunroof/95.5 cubic feet with sunroof:
Cargo Volume: 14.8 cubic feet (11.8 when equipped with full-size spare)
Curb Weight:Base Model: 3,336 lbsLeather Model: 3,369 lbsLeather 6mt: 3,398 lbsAWD Leather: 3,677 lbs
Fuel Capacity: 20 gallons
2003 EPA Fuel Economy Estimates (City/Highway): Auto 18/26 6mt 20/27 AWD 17/24
2003/2004 G35 Coupe
Horsepower: 280 @ 6,200 RPM
Torque: 270 lb-ft @4,800 RPM
Suspension:Front: Sport-tuned independent, forged-aluminum multi-link with coil springs over shock absorbers, stabilizer bar.Rear: Sport-tuned independent, forged-aluminum multi-link with coil springs, outboard shock absorbers, stabilizer bar.
Valvetrain: DOHC, 4 valves per cylinder with microfinished camshafts and Continuously Variable Valve Timing Control System (CVTCS) for intake valves.
Intake system: High-flow tuned induction system with micropolished tract and ports
Fuel Delivery System: Sequential multi-point fuel injection
Brake Rotors:Standard: 11.65” x 0.94” ventilated front rotors/11.5” x 0.63” ventilated rear rotorsBrembo: 12.76" x 1.18" ventilated front rotors/13.07" x 0.87" ventilated rear rotors
Turning Diameter: 37.4 feet
Wheels: Standard: 6-spoke 17” aluminum-alloyPerformance/6mt Model: 7-spoke 18” aluminum-alloy
Tires:Standard: 225/50R17 V-rated all-season front 235/50R17 V-rated all-season rearPerformance, 6mt: 225/45R18 W-rated front 245/45R18 W-rated rear
Wheelbase: 112.2
Overall Length: 182.2
Overall Width: 71.5
Track (front/rear): 60.4/60.6 with 17” and 60.4/60.8 with 18”
Minimum Ground Clearance: 6.3
Coefficient of drag: 0.29 Cd/0.28 Cd with Aero
Head Room (front/rear): 39.2/34.7
Leg Room (front/rear): 43.8/31.4
Shoulder Room (front/rear): 53.7/52.7
Hip Room (front/rear): 53.6/48
Interior Volume: 86.6 cubic feet without sunroof/84.9 cubic feet with sunroof
Cargo Volume: 7.8 cubic feet
Curb Weight:Base Model: 3,416 lbsLeather Model: 3,422 lbsLeather 6mt: 3,435 lbs
All info taken from Infiniti.
w1ngzer0
Car: Pfft. i don't own a box
Question about the sedan's awd system. Is that computer controlled or do you have any kind of control like in the R34?
Carkeeper
Car: x
No, I have a G35x with intake and cams. It is truly ATESSA controlled but not with hydrollic clutches but magnetic clutches and the aforementioned ATESSA controller, has 50-50 all time drive "SNOW" switch. Not as aggressive control as my R32/GT-R, by will still out handle most cars.
Crashtest77
Car: 2003 G35 coupe
what was the actual name of the white color for the 2003 model
Andy_V35Sky_350GT
Car: 2003 Nissan Skyline 350GT
What are the mechanical differences, if any, between the 350GT and the G35?
blESSEd5
Car: 05 metallic blue g35 coupe
I have a question about sport package of 05 g35 coupe with the 19" wheels and sport tuned suspension ... what kind of air intake does it have ? is it possible that it comes with a AEM cold air intake stock? Because i bought my car 2 weeks ago and i have that intake.
ampsucker
here's some more info on the
2007 Infiniti G35 SPORT 6MT Sedan
(from caranddriver.com)
Vehicle type: front-engine, rear-wheel-drive, 5-passenger, 4-door sedan
Estimated price as tested: $36,000
Estimated base price: $32,500
Options on test car: Premium package (includes sunroof, 10-speaker sound system, and heated front seats)
Major standard accessories: power windows, seats, and locks; remote locking; A/C; cruise control; tilting and telescoping steering wheel; rear defroster
Sound system: Bose AM-FM radio/CD changer, 10 speakers
ENGINEType: V-6, aluminum block and headsBore x stroke: 3.76 x 3.20 in, 95.5 x 81.4mmDisplacement: 213 cu in, 3498ccCompression ratio: 10.6:1Fuel-delivery system: port injectionValve gear: chain-driven double overhead cams, 4 valves per cylinder, hydraulic lifters, variable intake- and exhaust-valve timingPower (SAE net): 306 bhp @ 6800 rpmTorque (SAE net): 268 lb-ft @ 5200 rpmRedline: 7600 rpm
transmission: 6-speed manualFinal-drive ratio: 3.69:1, limited slip
Gear: Ratio: Mph/1000 rpm Max test speed I 3.79 5.5 42 mph (7600 rpm) II 2.32 9.0 68 mph (7600 rpm) III 1.62 12.9 98 mph (7600 rpm) IV 1.27 16.4 125 mph (7600 rpm) V 1.00 20.8 158 mph (7590 rpm) VI 0.79 26.4 158 mph (6000 rpm) DIMENSIONSWheelbase: 112.2 inTrack, front/rear: 59.8/59.8 inLength/width/height: 187.0/69.8/57.2 inGround clearance: 5.3 inDrag area, Cd (0.29) x frontal area (25.2 sq ft, est): 7.3 sq ftCurb weight: 3583 lbWeight distribution, F/R: 53.3/46.7%Curb weight per horsepower: 11.7 lbFuel capacity: 20.0 gal CHASSIS/BODYType: unit constructionBody material: welded steel stampings
INTERIORSAE volume, front seat: 55 cu ftrear seat: 41 cu fttrunk: 14 cu ftFront-seat adjustments: fore-and-aft, seatback angle, front height, rear height, thigh support; driver only: lumbar support, upper and lower side bolstersRestraint systems, front: manual 3-point belts; driver and passenger front, side, and curtain airbagsrear: manual 3-point belts, curtain airbags
SUSPENSIONFront: ind, unequal-length control arms, coil springs, anti-roll barRear: 1 control arm, 1 lateral link, 1 trailing link, and 1 toe-control link per side; coil springs; anti-roll bar
STEERINGType: rack-and-pinion with variable hydraulic power assistSteering ratio: 16.4:1Turns lock-to-lock: 3.1Turning circle curb-to-curb: 35.4 ft
BRAKESType: hydraulic with vacuum power assist, anti-lock control, and electronic panic assistFront: 13.0 x 1.3-in vented discRear: 13.0 x 0.6-in vented disc
WHEELS AND TIRESWheel size: F: 7.5 x 18 in, R: 8.5 x 18 inWheel type: cast aluminumTires: Bridgestone Potenza RE050A; F: 225/50R-18 95W, R: 245/45R-18 96WTest inflation pressures, F/R: 33/33 psiSpare: high-pressure compact
C/D TEST RESULTS ACCELERATION Seconds Zero to 30 mph 2.0 40 mph 2.8 50 mph 4.0 60 mph 5.2 70 mph 6.9 80 mph 8.6 90 mph 10.5 100 mph 13.1 110 mph 15.8 120 mph 19.0 130 mph 23.8 140 mph 30.2 150 mph 38.2 Street start, 5-60 mph: 5.8Top-gear acceleration, 30-50 mph: 8.750-70 mph: 7.8Standing 1/4 mile: 13.9 sec@ 103 mphTop speed (governor limited): 158 mph
BRAKING70-0 mph @ impending lockup: 160 ft
HANDLINGRoadholding, 300-ft-dia skidpad: 0.87 gUndersteer: minimal moderate excessive
FUEL ECONOMYEPA city driving: 18 mpgEPA highway driving: 25 mpgC/D observed: 17 mpg
INTERIOR SOUND LEVELIdle: 41 dBAFull-throttle acceleration: 79 dBA70-mph cruising: 67 dBA
Andy_V35Sky_350GT
Are there any stock 03-04 acceleration times for the coupe? I read 5.6secs 0-60mph but don't know how accurate that was.
AlpineReliant
Car: 2007 G35 Journey Silver
dont remember my sources, but i read somewhere 0-60 in 5.5 and est. 1/4 in 14.2 might have been motortrend? or automobile, cant remember. hope that helps.
g354life
Car: '04 Infinit G35 Coupe, Brilliant Silver
I believe its White Pearl
A.Tech
Car: 1998 Nissan Maxima SE Black on Black 5-speed, and yes. I know my avatar is a Gen 5... lol
I thought it was Desert Platinum...
