Hello guys,
Just bought an 05 Infiniti G35 and I'm having problems with it. Engine turn-over takes much longer than it should. Took it in for diag and mech told me that tone wheel may be mismatched causing a turn-over delay. He checked wiring and everything (wiring harness, signals from cam & crank pos sensor, wiring from ECU to each sensor) is fine. Suspects problem only from possible tone wheel difference. Anyone know any great, dedicated Infiniti Mechanics that I could take car to in Ohio OR do you happen to know what actual problem is? Thanks
