G-Series FAQ and how-to
Postby joe603 » Wed Jul 16, 2008 11:13 am
Please email one of us if you have a problem with anything in the forum. Our email addresses can be found in our profiles.
Technical Forums:
We have additional forums to discuss specific G-series issues. These are:
G-series Forum Main Page
VQ Series engines
Online Mechanic
Other G-Series Links:
G37Driver Main Page
G35club Main Page
FACTORY SERVICE MANUALS
G35 reliability poll
Members Rides
G Members intro page
Reviews
GENERAL
2009 G37 sedan TSBs
G35 tips and tricks
Gasoline Octane info
G35/350Z model engine info
Manuals and Guides
G35 Tech Specs
Abbreviations and slang
Foolproof coil test
Turbo Answers
Turbo guide
Nitrous Oxide Answers
Aftermarket Parts Suppliers
G35 reliability (Please sign up if you're new)
TSB Lists
Recal and more TSB info
How to post photo
How to use quote boxes
MAINTENANCE
Maintenance Schedules
Clutch adjustment for G35/350Z
Air Filter Replacement
Manual Transmission Fluid Change
Change clutch fluid
03-06 G35 Spark plug replacement
07+ G35/G37 Spark plug replacement
G35 Accessory Belt Change
ENGINE
Invidia Catback Installation
Electric Fan Conversion
Forced Induction Forum
07-08 G35 sedan Injen intake install
Exhaust Install
Checking Infiniti ECU Codes
Plenum spacer install
Engine cover mod for 5/8" spacer
Clearing CEL for High Flow Cats
Clearing Codes on the G35
G35 ECU reset procedure
Twin Turbos for G35
Exhaust Poll and Info
Clutch and Flywheel
G37 Oil Cooler install
ELECTRICAL ACCESSORIES
G37 HID Bulb Replacement
G37 headlight Bulb Replacement
How to install halo's - 03-07 G35
How to Bypass Video on a 2008 G35
G35 headlight/foglight/side bulb without removing headlight
Homelink programing
G35 Bulb replacement stock part numbers
EXTERIOR
Painting a grill
Wetsanding 101
G35 Window fix
G35 door lock fix
G35 Windshield wiper fix
Rear Spoiler Install
INTERIOR
2007+ Sedan, 2008+ Coupe hidden Diagnostics and Adjustments Menu
Replacing in cabin filter
07 G35 Sedan Stereo Removal how-to
Low-budget Fix For Crappy Bose Systems
Tweeter DIY install
Wood Trim Guide
SUSPENSION, BRAKES, WHEELS & TIRES
G35/G37 OEM wheel specifications & after-market wheel offsets
Strut Tower Brace Install
G37 Coilover install
Brake replacement procedure
Brake Poll and Info
2006 350z suspension
TIRE SIZE CALCULATOR
joe603
Car: 09 G37S sedan
Return to G35 and G37 Engine, Drivetrain & Tuning
