I've never replaced spark plugs or coil packs on a car before, but I figure it's time to man up and make it happen on my Q!
Got the car recently, cant find any recent records or any plug changes. Even though car seems to run smooth and I'm not getting any codes I figured it was time, and might as well replace the packs while I'm down there too. Just want to make sure I dont screw anything up and would appreciate any advice. I've already looked at several videos and other forum posts on this, just want to get a better idea before I start.
THINGS I'M PLANNING ON BUYING
-NGK 7090 Platinum plugs from AutoZone
-Coil packs from AM After Market Auto Parts, seem to be a good deal at $120 for all 8 and have 10 year warranty (
http://www.am-autoparts.com/Infiniti/Q4 ... hgod7YYPsw)
-A bit of anti seize for the threads
-Some sort of electrical fluid for inside the coil packs where they connect to the top of the spark plug (recommendations?)
QUESTIONS I HAVE
1. Do I need to gap the plugs?
2. Are there rubber gaskets below the plugs, or are the plugs just sitting on the block?
3. How much torque on my torque wrench is needed to seat the plugs?
4. Any useful tips/tricks from you that you've found?
Thanks!
