Fuses
whitedragon551
Car: 2015 Nissan Murano Platinum
I have recently had some issues and am selling my SUV. My dad was talking to a guy at work about purchasing my QX4. My dad explained the issues I was having and the guy said he had something similar happen on an older vehicle of his. Turned out to be a fuse that was causing the transmission not to shift right.
My question is are there any fuses that would cause this issue in a 1998 QX4?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
If a fuse was blown somewhere, I'd imagine it would give a noticeable sign somewhere - i.e. trigger a check engine light, or some other obvious failure like a light failing to illuminate somewhere, or something nonessential like your horn not working.
I have read of a dirty MAF causing shifting issues, so you may want to check your MAF sensor to see if it has accumulated any grime.
whitedragon551
The maf was cleaned in the process. To late now. Sold it this morning.
