Eikon »
https://forums.nicoclub.com/eikon-u15727.html
Tue Aug 26, 2008 10:09 am
Cliff Notes.. Always remove the oil dip stick before replacing the oil pan.
I picked up a 1995 Nissan Quest Minivan as a "random act of kindness". A friend of mine from church and I decided we should help out a local minister who works with kids full time and has been struggling to maintain on his crummy stipends... So we put up some funds, and I looked around for a while for reasonable priced van.
I found a Quest that was in nice shape, but had some paint imperfections. I snagged it for a really nice price... or at least I thought.
I asked about the oil stain on the driveway and was told that was from another vehicle. When I got it home I left it there for an hour and came back to find a large puddle of oil. Uh-oh!!
So I jack up the front of the van and find that the oil pan has a huge dent in it and is leaking like a screen door in a rainstorm.
Now I've swapped oil pans before. Normally it's an easy process. Normally the manufacturer makes a two part oil pan or at least a seperate sump that can be detached and replaced without a great deal of work. Not the VG30de... no sir.. That sucker is one piece.. the whole bottom of the motor.
So I snagged a replacement oil pan and scheduled some time at my friends house to use his lift.
What a pain in the neck this job was. First you have to remove the exhaust piping from the header around the motor and underneath. Then you have to support the motor itself with a jack from below or a lift from above. The reason you have to support the whole motor is that the crossmember has to be removed in order to get the oil pan off.
So after busting my knuckles underneath an otherwise very nice van... I finally managed to remove the oil pan and bolt the new one on.
I put the pan on, put the transmission mount plates back on, put the engine mounts back on, put the crossmember back in, put the exhaust piping back on, filled it with oil, and dropped it from the lift.
I fired it up... and heard a terrible engine sound... The sound of the dipstick hitting the rotating assembly as it spun. Yikes!!!
So I shut the thing down and tried to figure out what I'd done wrong....
Well, I forgot to remove the dipstick prior to putting on the new oil pan. The dipstick has a little bracket guide welded to the side of the oil pan to keep it in a proper position. I installed the new pan and didn't get the dipstick back into the guide channel.. so it was pinched against the outside of the channel and pointing straight at the internals of the bottom end. Stupid Stupid Stupid!!!!
So I had to do the whole job over again.
