So I got a 15 year sitting barn fresh 1982 for $100 which has a z24 8 plug motor in from what I have read on here. I cleaned the plugs put new tires on it new gas and fired it up ran up threw the woods for about 3 hours ran threw 2 small mud holes pulled out and the truck shut down, (Don't think the mud or driving had anything to do with it I didn't beat it just idled around) anyway after about 4 min. of cranking it fired up and it ran for aprox. 1/4 mile then shut off and is now dead in the water, I found that I was not getting any fuel to the accelerator pump. looked in a little deeper and found now power at the fuel pump, traced that and found an ignition power wire rubbing on the frame of the seat I repaired that replaced the fuse and now have good power and ground at the pump, plugged it in the first time and hummed for aprox. 3 sec. then shut down truck still won't start. I removed the inlet fuel line to the pump and the line was dry guessing I have a bad pump but wasn't sure I'm a diesel mech so the hole none gear driven fuel pump/ spark plug thing gets me at the moment but we are getting better do the fuel pumps on these hum vibrate or anything to let you know if they are running or is it possible the pick up tube in the tank was rusted and broke off. any help is appreciated
I have a very limited budget and don't wanna buy a fuel pump if I don't need to.
but I'm pretty sure that I'm going to run a hot wire threw the fire wall to a toggle switch then run a new wire to a new inline fuel pump with a regulator only question is how much fuel pressure do these norm run stock was thinking about 7psi but thats just a guess. that way I can match up the pump or at least get one that will supply enough. looking at the harness in this thing (pretty hacked) its going to be a trip figuring what all they did. on the + side everything else mechanical works good as long as it gets fuel that is.
. next is fab up a lift and get some 410 gears and get some 36" tires for it.
