The venting from the gas cap is normal? I've never encountered a car that pressurized its tank like this car does. Just seems odd to me. The leak was high in the filler neck so I think the tank was burping fuel after pressurizing. Then again I've been wrong before. I used to think the focus was a cool carRazi wrote:The "pssst" is normal.
As for the leaking, check all the fuel lines.
It is normal.Lord Umoja wrote:The venting from the gas cap is normal? I've never encountered a car that pressurized its tank like this car does. Just seems odd to me. The leak was high in the filler neck so I think the tank was burping fuel after pressurizing. Then again I've been wrong before. I used to think the focus was a cool carRazi wrote:The "pssst" is normal.
I'm positive it was actual gas. I smelled the puddle, the stench of gas carried pretty far, and it was removing the road grime from tank outside.mechanicalmoron wrote:Did you smell the puddle, and are you sure it's gas? It could be condensate from a freshly filled tank, that was hot until you filled it with thirteen gallons of cold gas. Maybe the hiss made you overthink.Razi wrote:The "pssst" is normal.
If you'd just filled up, if you splashed a little gas around the hole I think that pinhole drains into the fender, not the tank.... is the only other non-leaking thing I can think of.Lord Umoja wrote:
I'll pull the panel this weekend. It stopped leaking after I drove the car a bit.
Since you're saying you've done it....zmannz wrote:I f you plan to open that, save yourself trouble later and go ahead and replace all the soft lines you can get to. Last build I threw my walbro in, got the car done, then lost fuel pressure a day after it was running because the high presure line split right through. I went ahead and dropped the tank after that and got it all fixed the right way since I had access to a lift.
Dropping the tank isn't really hard, more just kinda awkward. It's held in with two straps under the car and a gasket around the filler neck IIRC. I dropped the tank on my coupe in preparation for a fuel cell. I did it on just jack stands and a floor jack.mechanicalmoron wrote:Since you're saying you've done it....zmannz wrote:I f you plan to open that, save yourself trouble later and go ahead and replace all the soft lines you can get to. Last build I threw my walbro in, got the car done, then lost fuel pressure a day after it was running because the high presure line split right through. I went ahead and dropped the tank after that and got it all fixed the right way since I had access to a lift.
I'm suspicious of my soft lines, especially given my suspicions of the garage that I had do my fuel pump (I pulled the thing out in the autozone parking lot, and then the register jerk told me that he had meant it was at the hub, a day away.... I jammed it in and limped to a garage, who messed everything up), and would like to do them.
How hard is it to drop it? If it's run down to a few gallons, is there a way to do it with the car on jackstands and access to one floor jack? Maybe with two people? Heavy or no?
Last time I was doing this, I couldn't reach the hardline, or even see it, in the space between the tank and trunk....Dimitri wrote:The lines coming out of the fuel tank can be replaced without dropping the tank.
Once you remove the fuel pump cover hiding under the trunk carpet, you can see the two fuel hoses coming out.
If it does turn out one of them is leaking, replace both and make sure you get fuel line for high pressure
And of course don't forget to relieve the fuel pressure from the lines before you start disconnecting them
Ahh, I assumed that the hardlines ran up to right by the top of the tank, but that would be waaaay nicer.Dimitri wrote:On the '90 hatch the connection to the hard lines is accessible by crawling under. A lot less fuss than dropping the tank
