lookadahdeh »
https://forums.nicoclub.com/lookadahdeh-u219197.html
Tue Nov 04, 2014 8:22 pm
Fellow Cima/Q45 lovers/ enthusiasts, I am in need of some technical advice if you will indulge me.
I have a 1991 Nissan Cima which I am trying to restore to a driveable condition after it was sitting nine years in a shed.
It was languishing in Barbados and I managed to get it running but it needed a starter motor and fuel pump plus a thorough clean up in and out.
When I bought the fuel pump I took the original to a parts place where they could only match it up by dimension (Cima was never imported into Barbados and was not on their database, this one was sent as a gift to an individual), It seemed an exact match visually except for the terminals, push on versus bolted.
I put it in and the car started well but wouldn't rev out. When pushed, it would start to hunt and waver, which I attributed to the fact that some cars cut the fuel flow when exceeding set rev limits in neutral. However, on subsequent visits, I managed to drive the car but, still, high revs were unattainable even having the engine cut out sometimes.
Driving was not easy as the suspension was all the way down and I couldn't translate what was written on the suspension reservoir cap (can't speak or read Japanese) and didn't want to bugger the suspension system up, especially things I don't understand nor have tools to attempt to fix.
Another point to ponder was that the price of the pump in Barbados was about US$90.00 and here in Vancouver, BC they are listed from CDN $150 (with core) $200 without ,the cheapest i could find, to $300 to $600 and in Lynden, WA, about US $190.
My query is
1 - would similar sized pumps and same in every visual way have different fuel outputs?
2 - would a pump that is able to comfortably start and rev the engine to mid range (2000 to 3000 rpm) be insufficient to power to red line?
3- Is this line of investigation plausible or should i look elsewhere?
The car was reportedly working well when it was put to rest.
4 - What is the minimum and maximum pump pressures needed for this engine's range of operation?
Thank you for any help and/or suggestions.
Mr. P
