supersnake83 »
https://forums.nicoclub.com/supersnake83-u35631.html
Mon Jan 12, 2009 10:24 am
Well,
Here goes the story. After taking a closer look, I think the problem was actually the short 2.5" hose connected to the fuel pressure regulator. What I was seeing and it is possibly seen in the picture (maybe not, though) is that the gas was shooting up from the hose and I thought it was leaking from the regulator.
After going to Autozone twice because I didn't know what rubber hose to buy the first time (I guessed at the size diameter and it was a hair too tight), the second second time I went there the guy showed me that there is a specific fuel injector rubber hose with blue lining in it, which in fact was the correct diameter size hose of the original.
I changed the little 2.5" rubber hose and it appears to be working (not leaking fuel anymore). However, the first time I tightened the upper clamp, I had it too far to the top of the hose and after I loosened it a little bit to push it down some, gas started shooting out. Is that normal for gas to be gushing out of that part of the fuel line?
Hopefully that was all that was the problem. Thank goodness that it was solvable and findable because I think I was driving with it like that for a few days if not weeks.
If that is not the problem, I will just replace the pressure regulator (it is only 75 bucks from Infiniti of Scottsdale). It was an easy job.
I've been smelling a hint of gas/exhaust while driving for a long while now and I wonder if it is because of the small exhaust leak I have or that (new found gas leak). If it was that (new found gas leak), then I cannot believe I was driving around like that for 3+ years. Maybe not though. Although it could have been a really small gas leak and it just now started to leak larger amounts.
I'll pay close attention to the smell when I drive from now on and see if there is a difference from way back.
Thanks so far for the input. If I have any other problems, I will post them.
Thanks again.
Geoff.
