Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Jan 14, 2006 3:06 am
Of course you data log the engine injector time UNDERLOAD. Not some faked up dyno which doesn't load the engine properly.
I must have multi-hundreds of feet of Consult paper with all LOADED parameters. I've tested over 100 Q engines from idle to redline datalogging every parameter along the way. I test my Q at least every 90 days [40 times in last 9 years] to obseve changes.This is my method of assuring that things are OK and near to spec.....engine swaps and major rehab work, after chain guides, etc. for customers.
The Consult will store 4.00 secs in 0.03 sec increments or 130 lines of up to 15 parameters simultaneously.
Of course this work is mostly in 1st gear, although I have about 60 test in 2nd gear to 98 mph......too much traffic to exceed 80 mph on street.
We have a perfect level long bridge where no one can pull out in front of you. Start at 55 [4,000] end at 85+ [6300 rpm].......takes 2 runs because it is more than 4.00 seconds. Easy to do a 4,000 [30 mph] to 7300 [55mph]in first gear in much less than 4.0 seconds........still I do that twice to observe heat effects.
To far and too time consuming to chassis dyno each car with engine work during the field test. I stopwatch a 50-80 mph acceleration test on the same section of road [have developed a temperature correction chart to adjust times to fine tune data].
My entire field test takes 15 minutes and 15 minutes to look over data for anomolies.
Since the HP peaks at 6,000 this is the point where the longest injection time is other than of course the torque peak rpm.
Worries me that people don't understand that the torque peak [~~4,000 rpm] is where the engine [each cylinder] consumes the most air and fuel per rpm. As the rpm climbs above this point less air per gulp flows in therefore less fuel......shorter injector open time.
Sure 6,000 rpm consumes more air per minute [than 4,000] but not 50% more since the VE has fallen by 15%. By 7000 rpm the VE is down by 30%+.
The injector time should drop from 11msec at 4,000 to 9 msec at redline depending on exact MAF voltage...........these numbers will vary based on air temp [density] by at least 8% [32F>120F=8%]...........that could be 0.9 msec variance.
For protection stock ecu doesn't lean the alreasy too rich injectors after 6,000 rpm. Why JWT reprogram works: less fuel and more advance as VE declines.
