- 1. take a look at the left(driver side) window wiper
2. look at the point there it connects to the bottom all the way at the end, is a cap that covers the 12mm bolt.
3. pop that cap off
4. loosen the 12mm bolt half way
5. jiggle the wiper arm till it moves/spins freely.
6. adjust it about an inch from its previous position and re-tighten bolt.
7. check the wiper action on full high speed making sure that enough gap is between the wipers highest resting point and the window/A-pillar.
DONE!
The original size is 26" driver side and 14" for the passenger side
Trying to get the new style of wiper (bracket-less) you certainly cant fit the smallest size available at most stores which is a 16 while still having the 26" driver side. So to circumvent this you have to get 1 size smaller in the left(driver) side to be able to fit the smallest size for the right(which happens to be 1 size larger than the oem size)
