Front Wheel Stud Replacement
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
PEZi
In this thread, we will be going through wheel stud replacement. Firstly, How do you know you need to replace a wheel stud? The answer is simple... whenever one or more becomes stripped or loose. If you see either of things starting to happen, replace immediately!
First!
For starters, you will need to read through The Front Brake Rotor Replacement Thread as the disassembling of the hub is described in detail there. Once accustomed with that process, we can move on to the simple act of replacing the studs!
Second
Knocking out the old studs. A simple process... With the hub down, and the studs facing up, hammer the old ones out! They will simply slide out the back side of the hub. Some force may be needed!
Third
Get the new studs, and with the back side of the hub facing up, slide them into place. Once again, hammer them into place. Some force will be needed here as well, but be more careful when installing, you don't want the new ones getting loose again.
Once they are all in, the hub can be reassembled (wheel bearings packed etc.)
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
nice.
Return to “Datsun 720”
