Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Tue Mar 09, 2004 5:28 am
Call Southwest Auto Works (link at the left). Tell them you are a NICO member. You should get a good deal. Do a search on "Struts", in the Infiniti General forum, and here. There are a few guys here, that have done a write-up.
It is a simple procedure. It took me 2.5 hours, and that included the tension rods, and upper links (and I put the wrong bump-stop in the RF strut, and had to remove it again. I used an air compressor, and rented a tool from Autozone, to compress the spring.
