Front Shocks 63 L320
1962-1965 Datsun L320 and NL320 forums - The truck that started it all in the US. All 320-specific topics and discussion can be found here.
devon's63
Car: 1963 L320-3-00530
Pic's to follow
Hello All
Any chance you have a part number for front shocks? Hope to find KYB's. But will go with other well known makes.
Thanks,
Kevin
Gemmer
Car: 1964 Datsun PU 320
Kevin,
A couple of days ago I sent a parts manual here to the site. You should be able to access it. If you can't, give me a shout and I'll look them up.
Gemmer
Kevin,
devon's63
Pic's to follow
OK I looked them up. Found part#56110-04300
Does anyone else know a part number that's not over 50 years old.
Someone must have already found something usable. Almost all of you have front shocks on your trucks.
Thanks, for any help you can offer.
Kevin
Conner
Car: SRL31101633
1964 L320
The following are listed for a 1965 520 truck and may fit, although I know that the rear shocks for a 520 are not a fit because they mount to the frame differently, the fronts may work. You may want to order a set and compare them to your stock ones to see if they appear to mount the same way and if not send them back. At this point I think we are down to trial and error.
KYB Part # 343208 (GR-2)
KYB Part # KG4605A (Gas-A-Just)
KYB Part # 565029 (Monomax)
devon's63
Pic's to follow
Conner
I will review your input. Sounds very reasonable. When I find out what the out come is, I will reply to all.
Many Thanks,
Kevin
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '62 PL 320 - parts :(
1 x '60 PLG-222
and many more Datsuns from 48hp to over 500hp
devon's63,
Be wary that you may have to machine the lower bearing/mount of the front shock as it may be too wide to fit on the lower control arm of your 320. I ordered all three today to see if any of them have the narrow lower mount.
Also if you are changing out your old shocks for new because your 320 drifts/jumps while going down the road, you might look at your upper rubber bushings, tension rod bushing, or sway bar bushings as these will cause more steering and tracking issue than bad shocks. And being 50+ years old the rubber is probably harden, shrunk in size, or missing pieces parts and is not doing its job. My '63's right side upper bushings have disintegrated, so it has excellent camber for drifting.
I'll do some digging for new bushing info/compatibility.
Andy
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '60 PLG-222
Confirmed. All three shocks have a bottom mount/bearing that is 1 1/4 wide, so you will have to machine it down to fit. Also be advised there is a difference in the length of the compressed shock. 7 1/8 vs 7 7/8.
Li'l Truckie
Return to “Datsun 320”
