Well, now I realize that not only may I need to lower the suspension member but I must lower the suspension member. So I went at the very first bolt which connects the upper link on the left-hand side to the suspension member and it feels like it's going to break the bushing on the upper link. I don't wanna end up having to replace the upper link as a result of this!
I also can't seem to figure out which other bolts on the suspension member need to be removed in order to lower it just enough.
Has anyone here changed the front left control arm on a Versa? Any tips on how to lower the suspension member, i.e. which bolts need to be loosened?
Here's a pic of the bolt and the transmission that's in the way:
