you think that would make my steering wheel shake? like i said, it only does it at speed. i know my motor mounts suck but that should make a difference all the time, especially at idle, where my steering wheel doesn't shake at all (except the very slight shake of the whole car due to poop engine mounts i presume).Ni2s4s0aSnX wrote:Motor mounts.
rotate the tires front-to-back... rule that out. I mean if they did a 1/2 @$$ed job of balancing your tires, i'd do it myself to rule it out (if i still have access to my votech school's wheelbalancer) visual check of outer tie rod ends & all the other suspension joints u mention would greatly help.95lstegman wrote:well i just had the wheels balanced a few thousand miles ago when i got the car running. i don't have that much faith in that shop, though. it was a sort of "well, they're close, and the car is so bad i can't drive over 45mph" thing.
the car sat for 2 years before i bought it and towed it away. once i got it running i changed the tires but only got used tires. so it could be the used tires are bum, or it could be that the monkey that used the balance machine isn't as smart as most monkeys. i mean, you don't have to read english to work it . . .or it could be a completely unrelated issue, like 17-year-old ball joints, tie rods/ends, etc. i'll give it a thorough check-up thanksgiving weekend.808DRFTR wrote:I'd check your tires by rotating, and by saying that you had them balance when you got your car running, how long was the car sitting? Tires could have flat spots
If its under braking I would say most likely issue with rotors. Yep, rotors can become warped again..low budget ones are more susceptible to warping.Wheel bearings would emit a humming sound when the start going bad. My rotors were unevenly resurfaced at 50mph slight front end shake, when braking shook a lot more.95lstegman wrote:i noticed when i step on the brake pedal the wheel shakes violently. 2 months ago i had the rotors turned and they were perfect. is it possible that i warped them? i don't ever remember stopping short at all. so either the rotors are too thin, stock brakes totally suck balls, or perhaps the wheel bearings are toast or something else that cause the wheel to shake under braking. i'd like to vote that stock brakes totally suck balls, personally. gives me an excuse to upgrade .
