Gold Digger »
https://forums.nicoclub.com/gold-digger-u15335.html
Sun Jan 24, 2010 12:06 am
So, last night I was having some drinks with another GT-R owner friend of mine (who coincidentally works for Nissan as a designer) and I asked about some free horsepower upgrades for the RB26DETT.
He told me about the in-line restrictor oriface for the stock boost control solenoid.
If you don't know, there is a solenoid on the R32 and R33 GT-R (maybe the R34, but I don't know for sure at this time) that has this little fitting in it to limit stock boost to about .7kg. A fairly well known secret down in Australia is that if you remove this fitting from the hose going to the solenoid, you can get 1.0kg off boost from your turbos.
But, be warned. Long runs at this boost level in the R32 and R33 can be hazardous to your turbos because your exhaust wheels are ceramic. If they get overheated, they have been know to grenade and cause all sorts of damage. Small burst here and there are fine, though.
To find this fitting, locate your stock boost control solenoid on the driver (left side if you are facing the engine bay) fender. There will be two hoses that are attached to it. One will have a yellow band about half an inch down from the solenoid. Squeeze right at that yellow band, you will notice that there is something inside there.
Here's how I got mine out.
Disconnect the hose from the solenoid and remove the squeeze clamp. Next, spray a very small amount of silicone lube down into the tube, but just a little bit.
Using a set of adjustable flat nosed pliers, easily squeeze the fitting up and out from the bottom, taking care not damage the hose. Just keep slowly working your way to the open end of the hose using this method till the fitting comes out. DON'T DROP IT! You may need to use it again in the future.
Replace the squeeze clamp to the hose and replace the hose on the solenoid. Test drive and enjoy 1kg of boost in your R.
The whole process shouldn't take more than 10-15 minutes for a somewhat experienced wrench turner.
What I noticed after removing the fitting was, of course 1.0KG of boost (although it did rise every so slightly higher when boost first came on, but settles right at 1kg very quickly and no boost creep), increased boost response, decreased spool up time.
**NOTE!!**Do not do this unless you have a boost gauge that is accurate. Either have one in KG/Cm or PSI. 1.0KG = 14.7psi.
If the boost pressure holds at over the limit of 1KG, you'll need to reinsert the fitting as it could mean the spring tension in the wastegate actuators is no good which will cause over boost and and you really don't want your turbos to go.
If you do need to reinsert the fitting, don't worry, you can still increase the boost.
Just take a drill bit set and find out which size drill bit fits through the fitting, then just increase the size a little bit till you get your desired boost level.
