sc2nr wrote:slickroger wrote:
what i did:just popped the relay off, put it in the space beside the connector it came out of. ran the turn on switch to the ciggarette lighter.
For the fog light mod you did, which wire did you tap into for power? I know it says cigarette lighter but on the cover for the box I don't have any labels for cigarette lighter. In that picture it looks like a small yellow wire but I'm not sure exactly which wire you decided to go with. Does anyone know what color wire would power the A/C relay? I know I can draw off that one as well.
thanks
Personally, I just cut a hole in the far right bottom corner of the factory A/C relay's plastic housing (this is when looking at the relay installed from the driver's side, as in
this photo; "far" referring to the side facing the passenger side) and created a length of wire that has a small alligator clip on one end, and a quick disconnect on the other to connect to the relay. I attached the alligator clip to the long pin/post and then connected the relay as
slickroger did above using more jumper wires. I can provide some photos if you wish. I'm not saying this is the best method, but it works perfectly for me and is easily undone if necessary, with no functional damage to the factory relays (short of the plastic housing, but that can be covered up with electrical tape if the mod is undone).
