JackCrackerMan wrote:So over the weekend I had the dealership (or should we call them the stealership?) install the fog lights on my 2011 Rogue. First, they installed the dongle with the Automatic lights switch (which I didn't have previously... but I did have the sensor so they work apparently). Second, and I didn't discover this until after they were installed and I went through the owners manual specifically for the fog lights, but the fog lights only work when the headlights are on?
The whole point of fog lights, from a practical stand point, is for them to be functional when in a FOG bank... you don't want your headlights on when driving into a fog bank. Much of the blame falls on me for failing to read that section of the owners manual prior to getting them installed but I was assuming through common sense that they would be functional when the headlights were off and the front park, side marker and tail lights were on.
Has anyone else come across this and figured out an easy solution?
technically speaking you are right. you dont want headlights on in the fog - but in the same token you want to be seen as well.
today's automakers make fog-lights as more of an accessory than an actual functioning part. its just a gimmick item that looks appealing.
most of the time they dont even point were you need them an require adjusting or brighter bulbs.
-almost every car now a days - you can not run the fog-lights independent of the headlights. they are only to be on during headlight operation.
you can changing this by: rewiring the wiring in the relay fuse box. snip a wire, and send it to the tail-light fuse and the fogs will come on with the 1st twist of the headlight switch.(i dont recommend this, but its possible. and has been done very often with the maxima's)
EXAMPLE:(2002 maxima)
The green dots indicate the position of the wires from the relay that need to be used to make this work. The red dots are the wires that you dont touch.
