Hi,
I have a 2003 G35 Coupe, well-maintained, 155K miles (I bought it new, so I'm the only owner). I need the following fluids flushed: Brake, differential, transmission, power steering and coolant. I also need new drive belts.
According to the Infiniti maunal, the recommended differential fluid is API GL-5, Viscosity SAE 80W-90*5, the recommended transmission fluid is Genuine Nissan ATF Matic Fluid J and the recommended power steering fluid is Genuine Nissan PSFII or DexronTMIII/MerconTM or equivalent ATF. Can I get these fluids flushed at any repair shop? Can I buy the recommended fluids from somewhere and have the shop use them?
Thanks!
