nightskyisme »
https://forums.nicoclub.com/nightskyisme-u129087.html
Mon Mar 16, 2009 6:19 am
Your flasher relay is looking for a certain (bulb) load, LEDS use very little current, so the flasher is no longer seeing this original load (flashes fast to indicate a burned out bulb)
You need to install "load resistors" in paralell with your LEDS on EACH side so your flasher can "see" this load once again and flash normally. They are cheap and available where you bought the LED units.
