Intake, exhaust, fuel injection, sensors, driveshaft, transmission, clutches, flywheels, manual swap components, differential, axles, cooling system, ECU, forced induction parts, catch cans, complete motorsets.
FL:S14 SR20DET Partout. Most Items Are New OEM
Postby Hoffman5982 » Sun Apr 22, 2012 12:40 pm
I am parting out my S14 SR20DET Notchtop. A little back story on this motor is I originally purchased it in Aug 2010. It never ran right and eventually found the problem to be a cracked ringland. This was only the beginning of my problems with it which eventually led to it being completely rebuilt. After the last tear down I started it up to find out it had a tick. I could never find the source but had a few people look at it who were pretty confident that it was not rod knock. Upon tearing it down, no bearing were spun or anything, so I'm just as lost as I was in the beginning. I finally gave up and ordered a new one. Almost everything has less than 3k miles on it.
I am located in Pensacola, FL
What I am keeping is the valve cover/coil cover. Also, the new motor was an automatic so I kept the clutch, flywheel/bolts, and tranny.
Shipping is offered on most things for an additional price of course.
I will update list of sold parts at the bottom.
S14 SR Head- $350-- Was hot tanked and decked. Valves were inspected and new valve seals installed. Lifters and rocker arms are fine. Does not include cams, but does include cam caps.
S14 SR Short Block- $800-- I'M NOW PARTING THIS OUT. MAKE OFFERS Also hot tanked, decked, & honed, and crank was polished. All new OEM pistons, 3 of which have literally 2 minutes of run time(4th was replaced when the original ringland was found. New OEM rings, also with only 2 minutes of run time. ACL Duraglide Main & Rod bearings. 2 of the crank bearings may need to be replaced, although the crank itself is perfectly fine. New OEM rear main seal. Does not include front cover or oil pan or ARP's. Does include timing chain stuff. I'd like to sell this together, although that may change if I have enough inquiries on parting.
S14 SR Coil Pack- $20-- 3 of the 4 coil packs have been sold, so I have a single left.
S14 SR Coil Pack Sub Harness- $30
S14 SR Cams- $80-- Good condition. Does not include cam gears
S14 SR VTC Solenoid- $40-- Works fine
New OEM Lifters- $250-- Full set of 8. Originally thought they were the source of the tick, but weren't. These were literally run for 10 seconds. When I heard the tick was still there, I shut it off and gave up. These cost me $400 shipped, so this is a good deal.
S14 SR OEM Water Pump-$15-- I have 2 of these. One came on the motor and works fine. Second was purchased new(less than 3k miles), but has a little crud on the blades as I only put water in the system due to repeated flushes and the motor sat for a while. Of all the problems I had, cooling was never one of them. One on the left is the one I ran. One on the right is the one that came with the motor. Clean pump sold!
S14 SR Fuel Rail- $30--Fuel rail is slightly bent(not kinked) making install a little extra effort. I never had a problem with it sealing or anything. You can see the bend in the second pic between injector 1&2
Injectors sold, still have rail.
S14 SR T28 Inlet & Outlet Things- $40-- The outlet has a slight flat spot that I'm assuming happened during shipping. I never had an issue with couplers leaking or blowing off from it though.
S14 SR Throttle Body-(x2) $30-- Both are clean, neither include TPS unless you want the auto TPS.
S14 SR Timing Chain Tensioner-(x2) $25-- Both work fine.
S14 SR Starter- $75-- It's from the automatic. I'm pretty sure, but not 100% sure, that it will work for the manual tranny. It's super clean.
S14 SR Alternator Brackets- $45-- Includes the main bracket, adjustment section, and lower reinforcement section.
S14 SR Upper Oil Pan- $50-- Has been sandblasted and is very clean.
S14 SR Engine Harness- $100-- Harness is in excellent condition. No broken or melted plugs. It is from the auto motor, but all the plugs look the same with the exception of the TPS plugs, which should be able to be easily repinned. Doesn't include Auto ECU
S14 SR Auto Package- $80-- Who wants a 5spd car? They're so lame. Turn your piece into a luxurious automatic. Includes tranny, torque converter, and flywheel thing/bolts. Looks fine, although the pan might be a little damaged. . WILL PARTOUT. Does not include transmission mount
S14 Climate controls- $20-- Work fine. 1 or 2 of the lights are out and some of the buttons are worn from use. Just installed DCC
I'm sure there are a lot of little tid bits that I don't have listed. If you don't see something feel free to ask. I will get pictures posted up tomorrow, as well as anything I remember. Ask any and all questions.
Thanks for looking!
*****Items Sold*****
-Turbo
-Intake Manifold
-o2 Sensor
-Lower Oil Pan
-Turbo Elbow
-CAS
-Water Neck
-VTC Gear
-TStat Housing
-Power Steering Pump
-Power Steering Bracket
-ARP's
-A/C Bracket
-Front Cover/Oil Pump
-Turbo Manifold
-Ignitor
-Boost Solenoid
-Harmonic Balancer
-Fuel Injectors
-Alternator
-A/C Compressor
Hoffman5982
Car: '95 sr20det 240sx
Re: FL:S14 SR20DET Partout. Most Items Are New OEM
Postby Hoffman5982 » Tue May 01, 2012 11:11 pm
Humpty Bumpty. AC compressor is gone!
Hoffman5982
Postby EzJones » Wed May 02, 2012 8:17 pm
hey friend, I want your harmonic balancer if You still got it. Just need to make sure by "a few chips out of it" means paint and not chunks of metal, let me know thanks!
EzJones
Car: 95 s14
Postby Hoffman5982 » Wed May 02, 2012 9:38 pm
PM'd!
Hoffman5982
Postby EzJones » Wed May 02, 2012 9:53 pm
awesome i can do that tomorrow, I can't pm you back cuz i just registered, that balancer is a 3 belt right? , lil hard to see on pic
EzJones
Car: 95 s14
Postby Hoffman5982 » Wed May 02, 2012 10:36 pm
EzJones wrote:awesome i can do that tomorrow, I can't pm you back cuz i just registered, that balancer is a 3 belt right? , lil hard to see on pic
Yes, it is. And awesome! I'll have it shipped as soon as the payment is received
Hoffman5982
Postby drivinsidewayz86 » Thu May 03, 2012 10:23 am
Is the crank forsale
drivinsidewayz86
Car: 89 240sx , 90 240sx , 90 240sx , 98 240sx , 88 hardbody 4wd,02 sentra se-r spec-v,95 240sx
Postby RawrSoft » Thu May 03, 2012 11:49 am
Hey! I need the injector subharness ( if you're willing to split ) and the coil pack sub harness. Wasn't sure if the harness you were selling included the coil pack harness as well, but if it does I'll buy the whole thing, if not, let me know what you can do!
Shipping would be to CA - 92562. Thanks!
RawrSoft
Postby EzJones » Thu May 03, 2012 3:46 pm
sorry man it will be a day or two I really want it tho so i ll let you know when Im ready
EzJones
Car: 95 s14
Postby EJ8 944 » Fri May 04, 2012 9:08 pm
Hoffman5982 wrote:S14 SR Boost Solenoid-$35-- Does not include ignitor. Whoever buys the ignitor or the boost solenoid first has dibs on the bracket for free.
So does this mean the boost solenoid is for sale? I'm confused by the wordning. :confused:
I'll take the solenoid if its available. LMK.
EJ8 944
Postby Hoffman5982 » Fri May 04, 2012 11:27 pm
drivinsidewayz86 wrote:Is the crank forsale
I'm trying to avoid parting it out at this time. I will let you know if that changes.
RawrSoft wrote:Hey! I need the injector subharness ( if you're willing to split ) and the coil pack sub harness. Wasn't sure if the harness you were selling included the coil pack harness as well, but if it does I'll buy the whole thing, if not, let me know what you can do!
PM'd!
EzJones wrote:sorry man it will be a day or two I really want it tho so i ll let you know when Im ready
It's all good, just let me know.
PM'd!
Hoffman5982
Postby nommarune » Tue May 08, 2012 5:13 am
i need the harness and ecu possibly some other stuff.
nommarune
Car: 1989 240sx se stock auto ka / 1987 rx7 manual 1.3b
Postby Hoffman5982 » Tue May 08, 2012 4:42 pm
nommarune wrote:i need the harness and ecu possibly some other stuff.
Enable your PM's. Also, I just wanted to make sure that you were aware that the ecu is for an automatic s14 SR.
Hoffman5982
Postby nommarune » Tue May 08, 2012 5:27 pm
didnt realize it was disabled try it again. Not really sure how to enable it but i think i did.
nommarune
Postby Hoffman5982 » Tue May 08, 2012 5:38 pm
I'm assuming it's because you only have 7 posts. I don't know what their limit is
Hoffman5982
Postby nommarune » Tue May 08, 2012 6:58 pm
you can txt me 9 0 4 4 1 5 7 8 7 9 im in jacksonville fl
nommarune
Postby SDRMIAMI » Wed May 09, 2012 8:46 pm
just txt u
SDRMIAMI
Car: 1989 240SX 800HP
Postby terribletopher » Fri May 18, 2012 5:19 pm
I was looking for the motor mount brackets that bolt to the block. do you have those? if so how much?
terribletopher
Postby jluck113 » Sat May 19, 2012 12:39 pm
im interested in the starter , possibly some bolts if u have them long mani bolt (center one) injector bolts ,and some misc little odds and ends shoot me txt 209-915-2142
jluck113
Car: s14 kouki project sr
Postby terribletopher » Sun May 20, 2012 1:07 pm
So 50 shipped. And they are s14 brackets. Send me your PayPal info.
terribletopher
Postby sly240 » Wed May 23, 2012 12:48 pm
Interested in the t28 turbo inlet and outlet adapters. How much shipped to 28307? Email me at Pmarkleyh4e@yahoo.com I have money in hand as long as shipping isn't crazy.
"some peoples kid's"
"IED'S SUCK"
sly240
Car: 93 240sx
Postby Hoffman5982 » Wed May 23, 2012 2:40 pm
sly240 wrote:Interested in the t28 turbo inlet and outlet adapters. How much shipped to 28307? Email me at Pmarkleyh4e@yahoo.com I have money in hand as long as shipping isn't crazy.
Replied!
I have also updated the list on what has sold!
Hoffman5982
Postby rswails » Tue Jul 24, 2012 7:23 am
Do you still have the head? Do you think anything is wrong with the head? Was this the same head that was installed when you said engine was ticking and you couldn't figure out what was ticking?
rswails
Car: 1996 240SX s14 kouki conversion sr20det s14 notchtop
1992 Nissan 240SX rb20det swap
Postby Hoffman5982 » Wed Jul 25, 2012 10:30 pm
rswails wrote:Do you still have the head? Do you think anything is wrong with the head? Was this the same head that was installed when you said engine was ticking and you couldn't figure out what was ticking?
I do still have it. I've looked over it and have found nothing wrong, and I'm pretty positive the problem wasn't in the head as it never made the sound before the final rebuild. Honestly, I personally think I put a rod in backwards or something.
Hoffman5982
Postby blitzin247 » Sun Jul 29, 2012 5:54 am
I know you sold your turbo, but if you know of any good used turbos for sale in your area let me know (I dont live to far away)
I am REALLY looking to upgrade my turbos with some t 28's or gt28r's
Thanks
J. Lind
blitzin247
Car: 2000 Audi A6 M6
*looking for t28 turbos to upgrade my K03s*
Ready to DEAL, LETS GOOOOO!
Postby cobhc » Sat Aug 04, 2012 8:00 am
do you have the cam sprocket bolts?
If you buy cheap and not nice, be prepared to buy it TWICE
cobhc
Postby Hoffman5982 » Fri Aug 10, 2012 12:34 am
cobhc wrote:do you have the cam sprocket bolts?
Sorry for taking so long to see this. I only have the exhaust sprocket bolt.
Also, I'm bumping this to announce that I'm parting the block. Make me offers, worst I can say is no.
Hoffman5982
Postby mrevo240 » Sun Oct 07, 2012 7:16 am
I'll take that throttle body. The one without the rust on springs. Email me inorbertsales@gmail.com.
mrevo240
Car: 95' Nissan 240sx SE W/ SR
Postby Hoffman5982 » Sun Oct 07, 2012 4:13 pm
mrevo240 wrote:I'll take that throttle body. The one without the rust on springs. Email me inorbertsales@gmail.com.
Emailed!
Hoffman5982
Postby Djfiniki » Sat Nov 03, 2012 3:41 pm
Hey man, you still have sr20det alternator bracket?
Email me at djfiniki@yahoo.com
Djfiniki
Car: 1997 S14
Next
Return to Engine / Drivetrain (for sale)
