Finally wired the consult!
whiplash willy
Car: 93 Coupe 90 SR Hatch
I just finished wiring the Consult Port up, anyone who hasn't done this should, it is very useful!
I have a 98 TypeX SR in my 90 240 hatch. The new SR ECUs can't be manually switched into test mode, nor do they have a flashing LED so you can read codes. My SR had always run rich so this was my best option in finding the problem.
I cut the consult plug out of a mid 90s altima out of the junk yard. I wired it up directly to the ECM harness.
Here is a pic of the plug (I think most are grey)
And here is the wiring diagram for the plug I followed. (off plmsdevelopments.com website)
**Note: Remember, the following is if you have a 89-90 which doesn't have the consult hardwired to the dash harness. If you have a 91-94 the plug should be on the driver side. You don't need to wire it directly to the ECM harness like I did, just wire it up to the dash plug.**
So basically, there are 3 green wires coming from the large ECU Plug of ECM harness that go to the dash plug at the end of the harness (wiring between the ECU and dash plug.) (Confirmed for a 98 s13 SR, please check your ecu pinout for other engines.)
TX wire: GreenCLK wire: Green/whiteRX wire: Green/black
You just need to match those up to the wiring diagram for the consult plug linked above.
There are also 2 additional wires you need to splice into on the ECM harness (wiring between the ECU and the Firewall.
Splice into the Black/white cable for the 12v power to the plug (this is the ECU power cable if you check your ECU Pinout), and then into any ground cable.
I extended the wires out about a foot for easy access.
Now since I don’t have access to Nissan’s Consult reader, I bought the USB interface cable and DataScan software from blazt. ( http://www.blazt.biz/ )
It has a ton of cool features, including realtime display and logging, 0-60 times, check ECU codes, timing set, and much more!
Anyways, I found that my O2 sensor is not working, probley my wiring somewhere. It is an awesome tool, I only wish I would have set it up sooner!
Modified by whiplash willy at 12:57 PM 7/30/2007
austins240
Car: 93 240SX HB, 89 Rolla GTS
NICE!!! i will look into doing this on my redtop! does the display have the ability to show knock?
tintdude69
Car: 90 Sr20 hatch..
no it doesnt show knock like a datalogger on a dsm does. which sucks and they should have made the software monitor it. i would really like to have that for my rb since they have 2 knock sensors on it
NewKleer
Car: Aus N14 Pulsar w/W10 SR20DET
tintdude69 wrote:no it doesnt show knock like a datalogger on a dsm does. which sucks and they should have made the software monitor it. i would really like to have that for my rb since they have 2 knock sensors on it
it cant do whats not possible - the ECU doesnt let you monitor the knock value, so there is no way to get it with consult. the "dsm" and anything else that monitors knock has to be hard wired up to it - consult stuff is all thru the consult port, no wiring.
