Uploaded with ImageShack.us
mexillis wrote:Looks good manhow much for the rotors?
cruzad3r wrote:how do u deal with the extra camber from the lowering springs?
i hope you are correct they look nice and i see a lot of my neighbors staring at the car now.EniGmA1987 wrote:TriNet rotors work great actually. Very good quality for the price.
jhuerto23 wrote:I'm going to go ahead and install it myself. I'll do a write up for anybody else that wants to install springs on their M. Did you torque the bolts back to specs?
Any update on this? Did it align within factory specs? Also do you have pictures of your car now after the drop settled in more?bicsintegra wrote:cruzad3r wrote:how do u deal with the extra camber from the lowering springs?
i have only driven the car about 10 miles or so since lowering it and with a 7 year old and a newborn(3 months) the preferred mode of transport is our expedition or f150 4door. i will have an alignment done in the next 2 weeks after that i will see how out of spec it is. for now the car only moves 25-50 miles a week if that.
No Squeaking of any kind. They have been really great rotors and well worth the cost.how r ur trinet rotors doing? did you have any type of noise after you had them installed? i still have a screeching sound about 50% of the time when i am driving. i only have about 500 miles on them is that long enough for the break in period? Any help would be apprecited,
Thanks
EniGmA1987 wrote:I read your PM but you dont have your enabled so I cant reply to you except here:
Thanks
I have warped them finally though. Have 25,000 miles with these rotors already. I was going about 100 and had to slam on my brakes when a car cut me off and put on his brakes, went from 100 down to 30 in about 2 seconds and warped them from the heat and force being applied. Still great rotors though.
as far back as i could get it to go.EniGmA1987 wrote:I have Hawk HPS pads.
Did you remember to compress the brake caliper back when you replaced the pads?
I have the Hawk HPS pads too and experienced a bit of scraping for the first few weeks I instaled them. I think they are a lettle thicker than spec 10mm for OEM pads. It went away eventually, but since you drive the car so little, it will probably take you a while to wear them down so the scraping stops.bicsintegra wrote:as far back as i could get it to go.EniGmA1987 wrote:I have Hawk HPS pads.
