Wildtraveler wrote:If the car you purchase is naturally a rear wheel drive car then it would be a s*** load of work to make it not rear wheel drive. Plus the rb25 is rear wheel drive and so is the rb26. What trim level of car are you referring to? Why would you want an RB25 tranny? Did you mean all wheel drive? You left a huge hole in your questions I think. For us to help you, you may want to add some more detail to these questions. Best of luck to you. I did a simple search of "rb25 rear wheel drive" and there are threads out there.
The RB26 is set up for AWD, not RWD. He would want an RB25 trans on an RB26 if he wants to go RWD. As far as I know, there is no way to successfully remove the transfer case from the 26 trans and make it just a standard RWD trans.
To the OP. I hope you're aware of what you're getting into. If you're planning on dropping a 26 into a 32 or 33 RWD turbo, you'll also need the ECU and wiring harness. There are probably a few more things you'll need, though. The 25 trans on stock gear set will not hold 850HP. You might be looking to have the trans built to handle that kind of power.
It takes a lot of money to get a 26 to that power range, anyway...especially if you want reliability. Cheap a** Ebay parts will only fail. You want that power, spend money. Plan on close to $8000 $10,000 minimum just to get the engine to that level. You can get a 26 to about 400-450 with a boost increase, injector replacement/fuel pump, intercooler replacement and a good ECU tune. Anything after those mods will have to be mostly internal. Cams, pistons, definately an oil/water pump, good valve springs, etc. The 26 is not cheap to make that much power.
