loystock »
https://forums.nicoclub.com/loystock-u10145.html
Wed Oct 14, 2009 4:28 pm
MarkC, Unless you have purchased an Infiniti Elite Extended Warranty, your Powertrain warranty has already expired. If you have an extended warranty, better stick to OEM fluid - Nissan Matic-D, P/N: 999MP-AA100P which can be purchased from IoS - infinitipartsUSA.com at a discounted price of $5.61/quart. The capacity of your transmission, RE4F04B, is 9 quarts. If warranty is no longer covered, then it's your call whether to use aftermarket Dexron III or the latest Dexron VI which is backwards compatible. Other forum members have used Mobil ATF, Amsoil or Royal Purple in lieu of Dexron III. Regardless which fluid you use, add a bottle of LubeGard Red after ATX service. Best way to determine if fluid is still in good condition is by doing a side-side comparison of current fluid and fresh ATF fluid (pinkish red) on a paper towel. To ensure ATX will last longer, better do a pan drop, replace filter, clean pan and magnets and use new gasket. Filter and gasket can also be bought from IoS. You will probably drain 4-5 quarts of ATF during a pan drop. Flushing is best done using a BG or equivalent machine. Some shops may refuse a flush beyond 85,00 miles if that's a the first time flush. Do not let them just do a drain and refill (3-4 quarts). Bring your own choice of fluid if service will be done in a non-Nissan/Infiniti dealership. Make sure the transmission has been run for @ 30 mins with flush chemical before the actual fluid exchange. Better bring extra fluids, say 12 quarts to ensure a complete exchange.
