fastest Q45 N/A g50. 1/4mile results! !
N/A Q45
Car: 94 Q45
Car #32-
N/A Q45
Car: 94 Q45
https://www.youtube.com/watch?v=o7Y4uue ... ata_player
https://www.youtube.com/watch?v=BEFZylA ... ata_player
Had traction problems and I only had a 10, 000ohm resistor and I needed a 15, 000ohm one to get it to run a little leaner up top.
Going to try some drag radials next time and the 15, 000ohm resistor hope to knock around .300 off the 1/4, they were saying the tires were still spinning as I went into 2nd..:(
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Lol using resistors to tune an engine, why not just get a used safc?
N/A Q45
Car: 94 Q45
asoomal wrote:Lol using resistors to tune an engine, why not just get a used safc?
Well I wouldn't buy one used. And in time I will buy one more then likely, the resistors cost a few bucks and can get the same results I'm going after for less cost :bigthumb:
Zer0_KooL
Car: 1995 Infiniti Q45 (G50)
well well not bad :dblthumb:
Turbon8er
Car: 93 RPS13 -Rojo
95 Infiniti Q45
77 Datsun 620 KC -Puddin' Tang
N/A Q45 wrote:Car #32-
1/4 mi ------ 14.0143
i'm probably the only one who finds this funny, but back in the days of beepers, pagers, whatev, my gf used to "beep" me 143 for "i love you", and it stuck. so now when i see that numeric combo it's what i think. your car ran the 14.ohiloveyou 1/4 mile at 100mph. that's kinda sweet. lol
N/A Q45
Car: 94 Q45
Lmao! Well I lets just say I hope to run into the mid 13.ohiloveyou's next time! Haha and I dont think the other cars were feeleing the love, tons of people were asking about it and couldn't believe the inside of of the motor was stock. Hell I even still have stock headers. I'd have say that the 4" Y-pipe I made for it the day before had alot to do with the times, but now I've put a 3" muffler system after the 4" Y-pipe to quiet it down until race days when I can take it off and as anyone could guess the lowed went up to the point I have to pedal it until 4000rpm.... the car would light the tires before from a stop but not like this! I'll post a link to that video in a min. But I'm going to get some 275s D-Rs for the rear and design a valve inside the 4" Y-pipe so I can have all this lowed end without hurting my topend.
N/A Q45
Car: 94 Q45
https://www.youtube.com/watch?v=2wF5OO- ... ata_player
235s just can't hold it..
Rather excited to see what it will run with 275s, variable exhaust valve and I add the suspension stops in the rear.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Can you summarize again for everyone what exactly you did?
N/A Q45
Car: 94 Q45
I would be more then glad too, just one problem. Where the hell is my old thread? Lol.
You all remember the one I had called N/A Q45 1/4mile in 13.5sec
That was from a gps but there was more then enough people on there who didn't believe that I could even get close to a 14.2 lmao and I remember someone was saying they would make a full public apology if I could get to 14.2..
I can't find my old thread soo did someone delete it?
I did what I said I would. Want the same respect back as in others do what they said they would. That's the whole point of this. And you don't need a turbo, N/A hauls a**! :dblthumb:
N/A Q45
Car: 94 Q45
I'll do something funny, I will list everything that is stock until I get a answer from my above post.
-the engine internals.
-drive system gearing, stall speed and weight of the drive system (not including rims and tires).
-Intake plenum from the runners down.
-exhaust headers (shape and size).
-fuel injectors.
-ecu.
-brakes.
-bumpers, undercarriage.
And that's all I can think of right now that is still completely stock.
N/A Q45
Car: 94 Q45
Just found this from another thread. Is this guy f*** kidding! $8k in mods and all he got was a 14.2.... wow. I like my $500 cost in extras much more-
congrats on getting out there and having some fun......Those are not all that bad of times for a stock regularly maintained Q. My 95 with about 125K went 15.8@88mph or so and it had always been dealer maintained, but not NICO maintained. NICO standards are much higher than dealer standards. I went from a slow 15.8 to 14.25 after about a very serious $8,000+ in mods over a 1 year period. I was/still am a mad man with dream of breaking into the 13sec barrier which is not possible in the Q if you are going to use it as a practical daily driver and not suffer too much longevity.
mattd1979
Car: 1990 Pearl White Q45 plain Jane with 266,000 miles. 2015 moonlight white metallic Q70L with 20” wheels, sport brakes and a 5.6L at 58,000 miles.
Is this the thread you had trouble finding?
102mm-throttle-body-t573395.html
N/A Q45
Car: 94 Q45
mattd1979 wrote:Is this the thread you had trouble finding?
No it isn't but thanks. It was called something like N/A Q45 1/4mile 13.5sec.
It was a huge thread with well over 2000 views I believe. After I got kicked off for a bit and was allowed back on i haven't been able to find it-
I know wes and others remember it very well. Just where did it go?- why would someone delete it? Unless maybe they didn't want others to actually see what I was saying and talking about.
It was a good rather heated thread but as I have just show with my #s makes alot of people look bad that were soo sure I was wrong.
elwesso
2007 BMW M Coupe
What was the ambient temp, just curious? You have to remember that when Rob ran those numbers it was in the middle of the summer with high humidity in Miami, so it was probably pushing 90°F (35-40°C) at least. If you were more along the 5-10°C range when you ran, that means air is about 10% more dense, assuming the same elevation and neglecting humidity effects. Also, Rob spent a lot of money because he did NONE of the work himself, and included rental car prices in those figures, so it's easy to say one could very easily achieve the same results much cheaper doing the same mods.
I removed the thread, not because of the info contained in there but because of all the irrelevant arguing.. It's not coming back, end of story.
Allow me to summarize what you've done to achieve this 1/4 mile time (please add as necessary if I missed something):
1. Changed to 270cc injectors and increased fuel pressure
2. Advanced timing on the CAS
3. Bigger TB
4. Cold Air Intake
5. Glasspacks
N/A Q45
Car: 94 Q45
#1 &#5 nope
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
Nice job man, sounds beastly.
N/A Q45
Car: 94 Q45
paranoidjack wrote:Nice job man, sounds beastly.
Thanks it is! Lol. Will be even more after I put a variable valve in the Y-Pipe and
Nitto 726-40206 - Nitto NT555R Extreme Drag Radial Details
275-Series Tire WidthTread Depth:6/32''Tire Overall Diameter:27.76''Tire Section Width:11.10''Wheel Diameter:15''Spec Wheel Width:7.5-8.0-9.5''Max Load @ Max Press:2150 lbs @ 44 psiRevs Per Mile:748Note: Bold type indicates measuring wheel width.
These^ :bigthumb: then peoples heads wil really be turning :rotfl
Turbon8er
Car: 93 RPS13 -Rojo
95 Infiniti Q45
take pictures of your exhaust setup.. i'm curious to see the 4" Y-pipe your talking about.
if you want an electronic (or manual) exhaust valve, you can get one from Summit or Jegs. I was looking at doing a full exhaust for quiet daily, and electronic valve(s) for dumping out a hot rod sound (no performance gain there). From my experience, dumping exhaust shortly after the headers (on n/a) kills power significantly. N/a motors need backpressure to make torque, but you probably know that.
just to give you an idea of what i'm talking about... except i'll probably do all my own piping. undecided right now.
http://www.summitracing.com/parts/pye-xvx10/overview/
http://www.summitracing.com/parts/sum-6 ... /overview/
I was just thinking... it would be kinda cool, once you get a working rpm window switch, to connect the trigger to the electronic cut-out valves. You could cruise around in sleeper mode, then punch it and have them open at like 4500 or something. You'll still probably incur power loss, but it'd be kinda trick, lol.
N/A Q45
Car: 94 Q45
Turbon8er wrote:take pictures of your exhaust setup.. i'm curious to see the 4" Y-pipe your talking about.
2.5"OD into 4"OD
After testing many different setups (true duals 2"/2.5", 45*->30* x-pipe 2.5", 45*-> 5* x-pipe 2.5"..ect )this 45*2.5-> 4" was night and day in mid to topend power. And if I can get the variable exhaust valve to work this thing will be nuts all over, I don't even have the car setup for max power for the street and it will still try to come around at 95kph when you try to pass someone lol. These dam 235 michelin pilots just can't hold it. I can make and sell you or anyone the same exhaust I have when it is done with the vvE if anyone is interested after I do some more testing once I get it installed.
And as for having cut outs, I am actually having a blast because the car is so quiet people don't expect it to run right by them. There was some kid today in probably his parents brand new Cadillac and he kept flooring it behind me like he was saying his car was faster, lol so put the good ole gas pedal down, tried to keep it in a staright line and well he kinda just stayed back after that and didn't do anymore of his flooring it b.s right behind me ha.
N/A Q45
Car: 94 Q45
3 things gave me the most gains, 4"intake, exhaust and 26* base timing.
mattd1979
What's the current mileage?
N/A Q45
Car: 94 Q45
Cams off 22mpg cams on somewhere around 25mpg but not 100%
Here's a picture of one of the x-pipes I made and tested 45*-> 30*
mattd1979
I meant how many miles are on the car or kilometers? Not bad though for the mpg.
N/A Q45
Car: 94 Q45
s*** sorry my bad. It has just over 220, 000km on it, so about 137, 000miles
Turbon8er
Car: 93 RPS13 -Rojo
95 Infiniti Q45
i can see why the x-pipe didn't yield a power gain, the angle is toooo sharp and the exhaust gas velocity is going to be destroyed by the direct intersection. The gas pressures are fighting each other at that point, and you'll probably lose power if anything.
If you'd like some great information on the subject, i highly suggest the book "Maximum Boost", by Corky Bell. It's mainly about turbocharging, but he goes into some great explanations and comparisons between n/a and Forced induction, and fantastic visual examples to better understand how such little details create serious results. It's only like $35 at Barnes n noble, and my favorite Non-fiction, lol.
N/A Q45
Car: 94 Q45
Turbon8er wrote:i can see why the x-pipe didn't yield a power gain, the angle is toooo sharp and the exhaust gas velocity is going to be destroyed by the direct intersection. The gas pressures are fighting each other at that point, and you'll probably lose power if anything.
It is know that you need a good merge angle (not too much or enough and you lose power or it shifts where the power is) I went with 45* in as alot of racing collectors from headers I have look up and researched are around 45*. It seems to be the out * that make a big difference in where the power is , atleast for me. Going from the 30*out to 5* out I noticed some topend gain, going to the 4" :mike seems to be working pretty dam good I'd say.
N/A Q45
Car: 94 Q45
X-pipes have to much hype from what I have read in testing them vs y-pipes I couldn't seem to find any that use in my mind a proper size y-pipe. Y-pipes are my choice and I would recommend this to anyone who wants their Q in the low 14s or even hit 13s
N/A Q45
Car: 94 Q45
elwesso wrote:What was the ambient temp, just curious? You have to remember that when Rob ran those numbers it was in the middle of the summer with high humidity in Miami, so it was probably pushing 90°F (35-40°C) at least. If you were more along the 5-10°C range when you ran, that means air is about 10% more dense, assuming the same elevation and neglecting humidity effects. Also, Rob spent a lot of money because he did NONE of the work himself, and included rental car prices in those figures, so it's easy to say one could very easily achieve the same results much cheaper doing the same mods.
3. Bigger TB
4. Cold Air Intake
5. Glasspacks
I think his rear end and transmission should have gave him the edge if he was making more power then me, if that's what you are trying to say-
I'm running the stock transmission and gear ratio and I can't hook now, put his on my car and it would never hook unless I had 300s probably-
Turbon8er
Car: 93 RPS13 -Rojo
95 Infiniti Q45
N/A Q45 wrote:X-pipes have to much hype from what I have read in testing them vs y-pipes I couldn't seem to find any that use in my mind a proper size y-pipe. Y-pipes are my choice and I would recommend this to anyone who wants their Q in the low 14s or even hit 13s
^that is one reason that GM stuck with the Y-pipe on the late model F-bodies (camaro, firebird), of course they call it a "Live" pipe.
i already killed one auto transmission by dogging the shiz out of it (i'm not going to tell you about how i thought it was cool to drift a v8 land yacht when i first got it. That might make me sound silly.) haha, so the only way my Q will ever see the 1/4mi is when i do a 6spd swap. But to be completely honest, i have no intention of drag racing it. It's a nice car, but not nearly as fast as my 240, which probly runs mid- high 12's. Maybe, idk for sure, but it'll beat my Q any day.
