Encryptshun wrote:Now, counterpoint.
MinisterofDOOM wrote:We thought Mach was an impenetrable physics barrier back in the '40s. Now we've got supercruise jets that lope along at nearly Mach 2 without much effort.
Our collective understanding of physics has increased a lot over the past couple centuries, but we still don't understand everything. It may not be as simple a solution as surpassing the sound barrier was, but I have we'll eventually find a way "around" the problems with FTL travel.
Encryptshun wrote:Philosoraptor says:
"If light could travel faster,
would it?"
C-Kwik wrote:That said, supposing the data is correct, it does not serve any practical purpose for FTL travel. We are made up of atoms, not neutrinos. FTL travel by a specific particle does not automatically imply FTL travel by all other particles. Not saying its not possible if the data is correct, but its a huge leap to jump to such a conclusion without even understanding how the neutrinos would be traveling faster than light first.
IBCoupe wrote:My understanding is that there are a number of organizations trying to find a way to communicate via neutrino transmissions. If possible, it'd eliminate one major obstacle towards interstellar travel/colonization.
Dattebayo wrote:I think the important questions is:
When did you get a freeway installed in your kitchen?
C-Kwik wrote:IBCoupe wrote:My understanding is that there are a number of organizations trying to find a way to communicate via neutrino transmissions. If possible, it'd eliminate one major obstacle towards interstellar travel/colonization.
If Neutrinos are constrained to the speed of light, it would still take 4.3 years to reach the next solar system. If the results the research group observed are an accurate indication of a natural speed of neutrinos, it will get there 0.0000002469% faster.![]()
That said, I would love to see neutrino based cell phones. No more signal degradation from being indoors or on the other side of the planet.
Encryptshun wrote:which is still better than two girls, one cup.
C-Kwik wrote:Propeller tip speeds reached the sound barrier before a plane did and this caused undesirable turbulence and shockwaves to occur.
PapaSmurf2k3 wrote:Greg could seriously run Nissan.
AZhitman wrote:C-Kwik wrote:Propeller tip speeds reached the sound barrier before a plane did and this caused undesirable turbulence and shockwaves to occur.
Other man-made devices achieved this long, long before the propeller. Pretty neat. Wanna take a "crack" at what they were?
C-Kwik wrote:That said, I would love to see neutrino based cell phones. No more signal degradation from being indoors or on the other side of the planet.
It appears that the faster-than-light neutrino results, announced last September by the OPERA collaboration in Italy, was due to a mistake after all. A bad connection between a GPS unit and a computer may be to blame.
Physicists had detected neutrinos travelling from the CERN laboratory in Geneva to the Gran Sasso laboratory near L'Aquila that appeared to make the trip in about 60 nanoseconds less than light speed. Many other physicists suspected that the result was due to some kind of error, given that it seems at odds with Einstein's special theory of relativity, which says nothing can travel faster than the speed of light. That theory has been vindicated by many experiments over the decades.
According to sources familiar with the experiment, the 60 nanoseconds discrepancy appears to come from a bad connection between a fiber optic cable that connects to the GPS receiver used to correct the timing of the neutrinos' flight and an electronic card in a computer. After tightening the connection and then measuring the time it takes data to travel the length of the fiber, researchers found that the data arrive 60 nanoseconds earlier than assumed. Since this time is subtracted from the overall time of flight, it appears to explain the early arrival of the neutrinos. New data, however, will be needed to confirm this hypothesis.
stebo0728 wrote:This whole speed of light speed limit thing, I dont buy it, at least completely. Light, afterall, is affected by gravity, requiring it to have mass right?
stebo0728 wrote:I mean a photon has mass, which it somehow only has at rest? Does it react differently with the Higgs field at rest, than it does in motion? Why do we even say its massless in motion, just to get around the FTL arguemnt, to make it work?
stebo0728 wrote:Not to mention, gravitational lensing occurs when photons are in motion, if they are massless in motion then how is gravity affecting them? The theory needs a bit of tweaking, perhaps there's another inverse coefficient missing that would account for reallllly small mass holders moving at light speed?
stebo0728 wrote:And do you really believe quantum dynamics and newtonian dynamics are seperate? I realize, for productivity sake, we handle them seperately, but I believe that is only due to the absence of a working unifying theory. In reality the 2 worlds are the same, and the unifying theory would theoretically effect both worlds, making newtonian physics more complicated probably, but also possibly making quantum physics a bit less fuzzy.
stebo0728 wrote:Also, so dark matter, sitting in pockets around the universe. Question: does dark matter absorb or reflect light passing into it? If it reflects, how do we differentiate an object being observed as being positioned straight ahead from an object's reflection being observed from the dark matter? Or to extrapolate that question, realistically dark matter would not perfectly absorb or reflect, but somewhere in between, causing some sort of distortion, which I assume we are not in any position to predict such distortion as we dont know what dark matter consists of. Maybe light accelerates or decelerates when passing through dark matter or dark energy? I realize these are all unknowns, but they are pretty significant unknowns.
stebo0728 wrote:Dark matter is hugely unknown. Its something that "has to exist" to account for what the rest of known theory says about the composition of the universe. My questions above are really currently unknown. Any info on wiki would be current theory, and thats cool and all, but still some of the nuances of how it behaves, whats it actually IS, and what not, is still up for grabs, and answers to those questions could have small insignificant, or huge effects on other aspects of current universe theory.
stebo0728 wrote:I understand what you mean about marrying relativity and newtonian theory. My point was that, once we join the two, newtonian theory would be exacted more, when necessary. Usually when figuring large scale motion or whatnot, quantum issues are ignored anyway because they have little perceivable effect on results, a body might end up 2 microns off from where you calculated it, but who cares. BUT, if we ever need more exacting calculations, they would then be available.
stebo0728 wrote:Interestingly, this could possibly lead to one day having computer models that can rather closely predict future results, in areas you might never imagine possible. Things that appear chaotic or random now, may end up calculated by highly precise computer calculations. I've often postulated, that were someone able to calculate particle motion at the quantum level, they might just be able to tell the future. Possibly even decision made by a human brain.
