Very good point! I searched the net and found what you were saying is very true.
Most low-beam headlamps are specifically designed for use on one side of the road or the other. Headlamps for use in LH-traffic countries have low-beam headlamps that "dip to the left", i.e., the light is distributed with a downward/leftward bias to show the driver the road and signs ahead without blinding oncoming traffic. Headlamps for RH-traffic countries have low beams that "dip to the right", with most of their light directed downward/rightward. Within Europe, when driving a vehicle with RH-traffic headlamps in a LH-traffic country or vice versa for a limited time (as for example on vacation or in transit), it is a legal requirement to adjust the headlamps temporarily so that the wrong-side hot spot of the beam does not dazzle oncoming drivers. This may be achieved by adhering blackout strips or plastic prismatic lenses to a designated part of the lens, but some varieties of the projector-type headlamp can be made to produce a proper LH- or RH-traffic beam by shifting a lever or other movable element in or on the lamp assembly.
Because wrong-side-of-road headlamps blind oncoming drivers and do not adequately light the driver's way, and blackout strips and adhesive prismatic lenses reduce the safety performance of the headlamps, most countries require all vehicles registered or used on a permanent or semipermanent basis within the country to be equipped with headlamps designed for the correct traffic-handedness. North American vehicle owners sometimes privately import and install Japanese-market (JDM) headlamps on their car in the mistaken belief that the beam performance will be better, when in fact such misapplication is quite hazardous.
mtcookson wrote:I wouldn't put them on. Since they drive on the other side of the road over there, the patterns are reverse to our lights. Basically the U.S. lights would put a pattern out like this:
_/ _/
While the JDM lights would do this:
\_ \_
Basically, you'd be changing the pattern enough that it could put some light in oncoming drivers' eyes. I would just a get a US spec replacement to avoid that scenario at all costs.
