If it's been taken care of, that sounds about right.t.mcginley.jr wrote: S14's get like 24mpg with the KA right?
Good to know about the fuel tank cracks luckily I haven't got any leaks in mine, that sounds like a pain in the a** to replace. But since I've had mine I get around 25-28 mpg on 87, depending on my highway/city miles. The motor is ~250-260k but this is after I've done most of the maintenance and replacing of parts (plugs, wires, fuel pump/filter, etc.)simmode1 wrote:If it's been taken care of, that sounds about right.t.mcginley.jr wrote: S14's get like 24mpg with the KA right?
But speaking of MPG, this reminds me of the one thing I hate most about S14 and why I can't wait to get rid of mine: They are prone to getting hairline cracks in the fuel tank and leaking fuel just to the inside of the driver's side rear wheel. That in and of itself isn't too bad. It's an old car. Replacing stuff is part of the game.
The problem comes when you try to replace the fuel tank.
1) They're becoming harder to come by undamaged. They're like $500 new & supplies are drying up.
2) Once you secure a new fuel tank, you gotta drop the whole rear subframe to do the swap, unlike the S13.
God, I hate S14's now because of stuff like that. I much prefer S13's.
Bokeh is your s14 manual or auto?Good to know about the fuel tank cracks luckily I haven't got any leaks in mine, that sounds like a pain in the a** to replace. But since I've had mine I get around 25-28 mpg on 87, depending on my highway/city miles. The motor is ~250-260k but this is after I've done most of the maintenance and replacing of parts (plugs, wires, fuel pump/filter, etc.)
Not that I know of. I believe the crack appears as a stress fracture from the straps that hold the fuel tank in place. Doesn't really seem like any efficient way of cushioning it. I'd say, try to make sure your car shakes, rattles & vibrates as little a possible to prevent that from happening. Alignments, proper tire pressure, suspension links, wheel bearings, subframe bushings, etc...t.mcginley.jr wrote:Yeah that does sound like a PITA, I'll have to look out for that. Is there anything you can do to prevent it from happening?
Out of curiosity, have you ever seen this happen to an s13? The fuel tank is a pretty scary component to fail, and, you'd think, a simple one that shouldn't. If it's made of the wrong steel, you have to worry about the actual chassis a bit more....simmode1 wrote:If it's been taken care of, that sounds about right.t.mcginley.jr wrote: S14's get like 24mpg with the KA right?
t.mcginley.jr wrote:Well most of the work I did was to get it running right (it was all jacked up when I bought it) so I figured I would add some stuff while I had the engine out.
Anyway, I'm really not going for anything with big power, I just need to get to work but I'd still like to have a somewhat sporty car. I have the majority of a TT swap in my garage including an engine but I think I'll just save that for when I find a good Z32 shell and I have more cash.
I was thinking I could trade it for a decent S14 with some cash on their end. Or just straight sell it and buy and S14. S14's get like 24mpg with the KA right?
