failure to turn completely over.
jgregory43
Car: Q45
I took 03 Q45 in the other day and had the shop replace the crankshaft and camshaft sensors. Got the car home and now will not turn over / start. It almost sounds like a poor connection or almost dead battery. I checked battery and is fine. So thinking i need to check installers work to see if connections are tight unless you have any other ideas. I had starter replaced early this year.
qship96
Car: 1996 Q45
why not take it back to the shop and have THEM diagnose/fix it?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
how did you check the battery?
jgregory43
Car: Q45
Checked with voltage meter. To diagnose whats wrong they want to charge me, but of course they will likely say its something else.
Q451990
Did you check it under a load? Voltage should be a bit above 12VDC at rest... not drop much under 12VDC during starting, and then be somewhere around 14.2VDC while the engine is running. What symptoms were you trying to cure by replacing the sensors?
