timh1972 wrote:i just checked and it does have bose and i saw the amp kinda small one at each speaker separate but connected ok so what is it i need to do?
What you need to do is search, because this has been covered about a billion times. However, I'm feeling nice today.
You need to get
one of these and install it between the new headunit you put in and the factory chassis wiring. This will allow you to use the Bose amps with an aftermarket headunit. If the amps are failing, i.e. one speaker crackling, then it's best to replace the faulty amp. Your other option is to replace all four speakers with aftermarket speakers and use your new headunit to power them.
