noDattebayo wrote:Wrong forum. GO post in the drift forum.
LollllScorchedNX2K wrote:go try it yourself? make sure you have a crate of tofu in the back and a formula atlantic engine in your panda-schemed hachi-roku to really simulate the "real thing"
Co-signed, i cant see a control arm lasting more than a few times (if not failing the first time) supporting the entire weight of a car.r34 gtr wrote:Ive got $5 saying if you tried the gutter trick you would dominate a lower control arm the first time out, and every subsequent time.
no.Sentientbydesign wrote:I can see a very skilled drifter with very slippery (not sticky) tires and smooth pavement being able to do the water thing.
Oh and let's not forget super stiff suspension (the type that makes your balls hurt).
OMG NOOB!GOnissanTOM wrote:sorry for the noobness,
But what the hell is the gutter trick?
X2. Gutter trick?GOnissanTOM wrote:sorry for the noobness,
which basically pulls him through the turn on the inside of the turn like he is on rails while the opponent slides to the outter corner do to the laws of physics.Razi wrote:The main character puts his wheels into the rain gutter and hooks his wheels onto it and goes around the corner very quickly without having to brake.
No matter how smooth you are the lateral forces will pull the water over to the side, so the water level has to be low enough to compensate for that. It does however make sure you aren't jerking around to the point that it sloshes out of the cup anyways.S13RainSpecialist wrote:so i was watching initial d and wondered if the thing that akumi does when he drives is possible. That thing is filling up a cup of water and drifting without spilling it?
so basically is it possible to drift/drive fast without spilling a cup of water?
Rally drivers actually use it all the time. Sure the stamped out OEM cheap control arms my not like it a lot, and looking to a cartoon to learn to drift makes you a huge ***....r34 gtr wrote:Ive got $5 saying if you tried the gutter trick you would dominate a lower control arm the first time out, and every subsequent time.
And now I can't have kids. Awesome.Mr1der wrote:real men use a hot lidless cup of coffee between the legs.
