BadQ45t »
https://forums.nicoclub.com/badq45t-u300.html
Fri May 24, 2013 1:22 pm
The tire is hitting the inside of the wheel well when I am turning, it doesn't do it just going over a bump, I tested that out pretty specifically. Two places on my way to work I know it pings the inside of the wheel well, one is a right turn that has a dip in to on a down hill where I am usually going about 50 mph, never had an issue there before. I can make the same thing going left and stiff as always. Also a freeway entrance where you go from 35mph to 65 pretty fast and also bends to the right with a little dip and ping on the top of the wheel well there.
What he has so far is take off the front tire and removed the strut from the car which is how he saw the bump stop was broken. He plans to put in fresh bump stops, which means he has to completely remove the spring as well.
At this point since I hoped to drive the car for another 1-2 years (it only has 98k on it and I have taken BEYOND good care of it) I have told him to get new sway bar bushings, remove the spring and ensure it was seated properly, repair the bump stops and put it back together. The tie rod ends were done at 70k but told him to replace those if they were at all suspect while he's in there. In Northern California an independent mechanic chargers $94 per hour (at least for a decent one) and the Infiniti dealership is around $175 per hour (Nissan is $145)....so he told me he'd keep to $600 bucks. I figure it is a good bet to see if he can fix it for that price and I can get that last 40k out of the car.
I will let you know how it comes out, Wes, you think I have it fixed??? If not the car is going to be a trade in for something (don't know what yet).
