Enjuku Racing »
https://forums.nicoclub.com/enjuku-racing-u482.html
Mon Aug 17, 2015 2:52 pm
PyroCell Elite Steel Fuel Container
New Product For Enjuku Racing!
Prices starting at only $815.00
PYROTECT’S NEW PYROCELL ELITE RACING CELLS ARE FIA/FT3 APPROVED FOR ALL MAJOR RACING ASSOCIATIONS.
The PyroCell from PYROTECT is our Top of the Line Fuel Cell. PyroCells are approved for use by ALL major racing sanctioning bodies. PyroCells are especially designed for: Pump Gasoline, Racing Gasoline, AVGAS and Gasohol (Not for Nitro or Alcohol Use!) The PyroCell comes complete with Full Foam Baffling, Aircraft Style Nut Ring, Gasket, Pick-up Assembly, Vent Check Valve, Standard Fill Plate with Rollover Check Valve, and a 5 Year Bladder Warranty.
STANDARD EQUIPMENT:
Ultra Durable Double Coated Urethane Fabric Bladder
Full Foam Baffling
Single 3/8 in., 1/2 in. or 5/8 in.Pick-up & one 1/2 in. Vent Check Valve Fitting
Internal Fuel Strainers
3 1/2 in. Threaded Cap on a Standard Modular Plate w/Billet Rollover Valve
Steel Container
OPTIONAL EQUIPMENT
Remote Fillers
Flush Cap
1 in. or 13/4 in. Vent Check Valves
Dual Pick Ups 3/8 in., 1/2 in. or 5/8 inches
Collector System
Sending Unit
For more options call to order.
