The web's first and most active forum for Nissan Versa owners!
Engine missfire
Engine missfire
Postby NissanATL240 » Fri Feb 24, 2012 5:19 pm
hey guys,
I have an engine missfire on my versa 2009. I first started having the problem in october 2011. While I was driving on the highway, the engine started to hesitate and then lost power. Then engine works but after driving for awhile, it starts to missfire again. What should I do? Anyone else experience this problem?
NissanATL240
Car: Nissan 240 SX
Re: Engine missfire
Postby itzme » Fri Feb 24, 2012 9:34 pm
check and see if your engine is still under warranty. If yes then bring it to a nissan dealer. They are going to check your oil and if its looking dark grudge then they are going to check if you have done your oil change routinely. They most likely will say they are going to take the engine apart and see if its like super dark and if it looks like you haven't got a oil change for years. If anything just show some receipts that you have gotten your oil change routinely. After that they most will replace your engine :D. That's what happened to me.
itzme
Car: Nissan Versa HB 09
Return to Versa Forum
