Gold Digger wrote:How is it that you don't have any fuel or spark when you try to start it with the key, but you can pop start it? I would say it's something in the ignition cylinder that is not activating the electronics when you turn the key to "Start" but it's on when you are in the "On" position. Still, that doesn't even make sense.
Not sure what it could be or how I can even help.
I would say to hit up the RB forum as this is a Skyline discussion forum. The RB forum can be found by scrolling down and looking at the navigation menu on the right of the page.
Hope ya get it worked out.
By the way, where are you located if you have a C33? I had one a few years ago before getting my R33 GT-R.
Yeh its a strange one, can push start it perfect but as soon as its under crank theres no ignition and fuel.
Thanks will check out the RB forum, I'm from New Zealand so there's tonnes of C33 Laurels here, it's just built to learn to drift in so thought it would be perfect, haha would definately prefer a R33 GT-R :P
Cheers
