nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Tue Jul 22, 2008 11:57 am
Not sure about the fuel level sensor. I haven't heard of those going bad. Try the Nissan Online Mechanic section.
Replacing the evap purge valve should fix that code. I figure it's worth a shot to fix that first and see if it helps with the other issue. An evap leak could conceivably mess with the fuel sensor signal, unlikely, but possible.
