I used:
I sprayed that everywhere, after i took off the plastic covers of course. I let that sit for a couple of minutes while I scrubbed the areas I could with a brush. I took it to those cleaning bays that have pressure washers and I think that may have helped a bit in removing possible clumps of grease. Some say high pressure is a no no for cleaning engines, and I agree which is why I sprayed the engine with water from a distance.
After the cleaner was rinsed, I dried the engine in areas that may form visible water spots.
I sprayed the same cleaner on the 2 plastic pieces that I had laying on the floor and rinsed it and dried it as well.
I put it all back together, shut the hood and continued to clean the front of my car to remove any possible overspray from the degreaser. It was going to rain that night so I didnt care for cleaning the whole car. That degreaser will ruin your paint if it stays on for a while so i made sure to spray it down with soap and water.
I drove it back home and used the engine heat to finish drying the engine. I sprayed a bit of
on the engine and plastic material but not too much. Very little is needed. I actually had to go and wipe off excess in certain areas but it still left a shine.
If any of you were wondering; I did not cover anything and I didn't clean the inside of the battery or brake fluid areas. They were already clean.
