RT22 »
https://forums.nicoclub.com/rt22-u137418.html
Sun Aug 22, 2010 4:44 am
Before adjusting cable put the truck up on jack stands and roll the back tire, then adjust the rear brakes so they are just starting to touch the drum and causing just a bit of drag. Many guys roll the adjusters down to get the drums on and never readjust them to be right on the drum. The adjuster is in the slot on back of the axle cover a small slit. You have to adjust the pads out with the drum on so it is right on the drum. Then pull emergency brake, if it is still not grabbing enough adjust the cable.
