First day home
It wasn't running (blown HG, bad injectors, turbos, etc..) so I hit the interwebs and the forums. Happened to find a nice JDM engine package in good shape from a shop in Canada. Ended up with a gift inside the bell housing thats worth what I paid for the whole package!
JDM engine
Got to work on the engine doing all the typical deletes and re-routes, added some exhaust I already had, then tossed the engine back in. First drive in a running Z was definitely worth the wait! ..but short lived.
Dropping in the new engine
All installed (shield your eyes!)
First "big" order
Thought this was a neat shot
About 200 miles after install, I started noticing a steady drop in power, and a loud screech or metal-on-metal squeal. The dreaded 'bolt in the compressor housing' story had happened to me. I had all the IC piping blocked off, but must have forgotten about the intakes and of course, the nut flew in there without me knowing. I used that as another opportunity to pull the engine and do some more 'while it's out' work. Replaced the turbos with another OEM set, then reinstalled the engine.
No more AC!
All buttoned up after some much needed cleaning
Made some brackets at a local machine shop for a VR-4 rotor swap
Always amazed at how much you can fit in a Z. My girlfriend and I managed to fit everything we had at school in the dorms
Used black 3M auto vinyl to black out the roof, stuff looks like paint!
Picked up some new wheels from a friend for less than it cost to buy new tires for the OEM rears, not my first choice but when you're on a budget...
Got a new wing and mufflers for Christmas
Sprayed the wing and wheels at a friends paint shop
VR-4 rotors were warped, so why not upgrade?
Picked up some Tein SS coil-overs off of an R32 for dirt cheap, still need to refinish them
Well about 2,000 miles later, ran a compression test and got 120's with the back two at 155, and also found out my oil pump was starving due to a dented oil pan. All problems that are easily avoided when tested/checked prior to engine installation. So this past summer, I pulled the engine out for the third time in 3 years, and wasn't putting it back in without complete confidence in the condition of all the parts and systems.
Engine pulled and torn down
Gasket matching in progress
Reassembly
One-off intakes in progress (new vs old piping)
I'm excited to say my first rebuild went great. I've put about 600 miles on it since the end of the summer and it runs and sounds like a new engine. The new turbos are still putting stupid smiles on my face, but theres still a lot of work to be done. Ive noticed with the twin disc and its extra clamping force, the pedal is quite vague when trying to consistently pull away without stalling. Needless to say, the cast clutch release fork will be going in soon.
I did however just weld up my exhaust (finally), and man did that help free up some power!!! Going from 2.25" with factory mufflers to a dual 3" is more than night and day. I still need to reposition the PS piping and add heat wrap up by the DP's. I'm also going to cut the tips at an angle with a bandsaw at school, and probably paint the piping/muffler bodies black so it does't look so obviously aftermarket (cops).
You can sort of see the HICAS eliminator I made in this pic too
Allllllll that brings you up to speed with where the car is now. I'm really happy with how far it has come, and I can finally start enjoying it like I've always wanted, but I can't stop now! Next on the list is custom IC piping and possibly a custom vertical flow FMIC, and a tune to compensate for all the new parts and flow. Then an E85 conversion with hopefully a standalone of some sort, and then some bodywork and fancy wheels
Current mod list:
ENGINE / PERFORMANCE
Fresh OEM LB with Cometic gaskets
Ported & Gasket Matched Upper and Lower Plunum
Garrett GT2560-r (.64 A/R)
HKS actuators
SS oil lines
Specialty Z 3" Downpipes
EM-Spec 3" test pipes
EM-Spec 3" quad tip axle-back w/slip joints
EM-Spec 2.5" intakes w/DEI "cool tape" (1800 deg.)
Spectre 6" Intakes with velocity stacks (in SMIC location)
Selin Translator (extended harness)
UAS Vertical Flow FMIC w/some 2.5" IC piping
BDE "Goose-Honk Killer" Recirculation Valve kit
Nismo Thermostat
Howe TT Radiator
Mishimoto radiator shroud
SPAL 15" electric fan
Z1 Silicone Radiator Hose
Z1 Silicone Complete Engine Hose Kit
AMS UD Pulley
AMS OD Water Pump and Alternator Pulley
Nismo 555cc Injectors
New OEM Wiring Harness
SUSPENSION / DRIVELINE
Tein SS Type-Na Coil-overs: +/- 20mm Ride Height, 15 Way Adjustable
Top Speed F.U.C.A.'s
Top Speed R.U.C.A.'s
Custom H.I.C.A.S. Delete Plate
CZP HICAS Outer Ball Joint Delete Kit
Revo 30mm Tension Rods
Energy Suspension Urethane PS Rack Bushings
Z1 Bronze Shifter Bushings
Z1 Short Shifter
Z1 SS clutch line
Nismo G-Max Twin-Disc
Redline Diff Fluid
New OEM transmission
Red Line MT Fluid
CHASSIS
Z1 13" Centric, Slotted BBK
Z1 Master Cylinder Brace
Axxis Ultimate Pads Front
Centric Posi-Quiet Pads Rear
Recoated Calipers
Rotor centers coated
Konig Tantrum 17x8 - Dark Gunmetal Met base w/ Dark Sapphire Met top coat
Falken Azenis RT-615 225/45/17 F
Bridgestone Potenze RE05A-RFT 255/40/17 R
R1 Performance Aluminum Open Ended Lug Nuts
Nismo Extended Studs F
15 mm Wheel Spacers F
20 mm Wheel Spacers R
ENGINE MANAGEMENT
Ash-Spec ECU @15-18 psi.
Greddy Profec B-Spec 2
Autometer Phantom Boost Gauge
3-Pod A-Pillar
COSMETIC / Visuals
6000k HID's (high and low)
LED License Plate Lights
Black Roof wrap
Black Pin-striping
Red Cam Covers
Wrinkle Black Coolant Hard-pipes
Sandblasted Upper Plenum with high temp clear coat
Wrinkle Black Balance Tube
Wrinkle Black Timing Belt Covers w/ Intake cam openings
High temp red Calipers
STEREO
JVC KD-A615 Head-unit
Polk 6" 2-way Door Speakers
Infinity Reference 6422 4x6 2-way rear speakers
U.S.Audio 500.1 Mono amp
Rockford Fosgate Wiring kit
Alpine Type-S w/ custom enclosure
Dynamat and egg crate foam throughout
WEIGHT REDUCTION/DELETES
EGR
PRCV
AC
Spare Tire
Carbon Canister
AIV
HICAS
Fiberglass Wing
Hatch weight
Bose Speakers
NEXT:
Custom aluminum splitter (possibly diffuser as well)
Custom IC piping (and intercooler?)
E85 Conversion
ECU (tune/standalone)
Racelogic traction + launch control
Paint with J-spec front, new moulding, windshield, and other goodies (probably keep the PMM color)
Wheels (too many, still deciding...)
