bimmer6 »
https://forums.nicoclub.com/bimmer6-u233362.html
Fri Mar 21, 2014 2:58 pm
Hello I have a 03 G35 coupe ,problem is when it starts up sometimes the instrument cluster does not light up, the heat/ac and radio don't work, everything else is fine. I fix this by tilting the steering wheel up or down until there is a good connection I hear a relay click and everything comes back on and it works until I turn off the car. It looks like theres a bad connection somewhere, I cant find what it is I tried disconnecting the different connectors to the steering wheel didn't work.. I saw on Edmunds forum many people had similar problem where ac, radio and dash either don't work or ac is always on and you cant control the radio.. some people had success by having the radio repaired by a shop or getting a new aftermarket radio.. in my case im not sure its the radio if it is fixed by tilting the steering wheel.. has anyone solved this problem?
thanks
