the converted »
https://forums.nicoclub.com/the-converted-u57671.html
Thu Sep 10, 2009 2:29 pm
The power to the dome light is always on, and is switched on the negative side. You can grab the power and a door trigger under the dash to power the lights, but it would not have the time out delay that the over head would. If you want to wire it up like that, then you would have to go to the controller (I'm not positive where it is) and get the signal from that. There is also a reasonable chance that adding the additional load of another light or two might be enough to blow the circuit.
I THINK that answers your questions, but if it doesn't, or you want a more detailed explanation, let me know.
