Eikon »
https://forums.nicoclub.com/eikon-u15727.html
Wed Oct 17, 2007 4:01 pm
Even though I don't have the funds to get it started and finished in one fell swoop, I do have all the time I need since winter in already sinking it's teeth into the "frozen tundra" of crappy Green Bay.
I started taking the car apart today.. had a blast doing it. There is nothing better than spending an afternoon in the garage with no interruptions, listening to music and working on your car.
Here's the what I'm starting with today:
What I'm doing:- Silvia front end conversion (stock metal fenders, stock metal hood, dual projectors, etc..)- Vertex body kit - Coupe doors (with seat belt relocation)
Here's a photoshop of what I hope to finish with for next spring:
First order of business is to remove the hood. Not a challange at all. There are two bolts on each of the hinges. Put the prop rod up, remove the bolts, continue to let the hood rest against the windshield, drop the prop rod, and pull the hood off.
In order to work on the front end you really need to have it up in the air and without the wheels.
My thought was that I would be able to pull off the fenders first. There are three 10mm bolts on top to remove. Open the door and you'll find a bolt in the jamb near the top. Pull the screws and snap the plastic retainers and remove the fender well plastic. Just behind the front wheel you'll find another bolt on the bottom of the fender. Inside the fender there is another bolt that requires a couple extensions to reach.. it's on the bottom of the connection at the door. Inside the fender on the front at the connection to the front bumper there are another 3 bolts. On the bottom of the fender there is a small brace reaching from the chassis to the fender secured with another bolt.Damn.. it still won't come off!I found the last bolt.. finally.. It's way up in the front tucked inside the front bumper. I tried forever to reach it.. multiple sockets, wrenches, etc.. no luck. Even pulled off one of the headlights to get at it from the top.. No dice!
I decided I'd have to pull the front bumper in order to get at that bolt.
So, I repeated the very same process on the passenger fender to get to the same stage.
Now to remove the bumper. There are two braces up by the radiator support.. just remove the four bolts. There is a strip of four bolts in the middle of the bumper above the radiator opening facing down toward the bottom. The secure to a metal strip. You've already removed the bolts that attach to the fender. Also on the passenger side you need to remove the windshield washer fluid container. Give the bumper a good tug and voila!
Now we can get that stupid fender bolt. It's just forward of the amber light in the fender. Yeah!! no more fenders!
Glad to have these parts off the car.
The car looks like a wreck!
I pulled the headlights assemblies out completely.
That's about all I had time for today.
Well.. maybe a few more minutes... I took a bit to test fit the rear bumper. Obviously it needs some prep and paint before going on the car for good.. but that takes money.. so it will wait a bit.
It's not quite on straight as the bottom behind the rear wheel is bowed out a bit.. once secured it will not flare out like that.
I like the angle.. I'm pretty excited.
That's all for today. Tomorrow's plan is to remove the USDM front bumper support. It will likely be a little bit of a pain because my intercooler is braced to it. The JDM bumper support is a little different. I need to figure out how to secure the intercooler to the new jdm bumper support.. hmm.... we'll see.
The next thing I want to do is install the new silvia headlights and center garnish. I'm not sure if I can do that before installing the bumper?
Clearly I'm better at taking things apart than I am putting them together. lol.
